Relationship between two coordinate systems.
Solving the first for u, u= (6-x)/sin(35). If we replace u in the second equation by that, cos(35)= (y- 3)/(6-x)/sin(35)= (y- 3)sin(35)/(6-x).In summary, the problem involves finding the value of u when v is constrained to 0, and the coordinates of the vector with respect to an arbitrary system. By constraining v to 0, we are on the u-axis and can use trigonometric functions to solve for the value of u. The coordinates of the vector can be found by dropping a perpendicular from a point on the u-axis to the line x=6 and using standard
theBEAST
364
http://img15.imageshack.us/img15/1671/capturetwy.png
Could someone please explain what is meant by "if v is constrained to 0"? Also how do you find a relationship between two axis of different coordinate systems? I really have no clue where to start.
Thanks!
Do you know how to find the coordinates of a vector with respect to an arbitrary system?
They're saying to constrain the v coordinate to zero.
'v is constrained to 0' means that we are on the u-axis. That's true because they are only asking for the value of u. Note that the origin of the u, v coordinate system is at (x, y)= (6, 3). Dropping a perpendicular from a point on the u axis, that is from (u, 0), to the line x= 6 gives a right triangle with hypotenuse of length u, 'near side' of length y- 3, and 'opposite side' of length 6- x.
The standard trig definitions of sine and cosine give sin(35)= (6-x)/u and cos(35)= (y- 3)/u.
FAQ: Relationship between two coordinate systems.
1. What is the relationship between two coordinate systems?
The relationship between two coordinate systems refers to how the two systems are related or connected to each other. This can involve the conversion of coordinates from one system to another, or the comparison of points or measurements in both systems.
2. How do you convert coordinates between two coordinate systems?
To convert coordinates between two coordinate systems, you need to know the mathematical formula or transformation that relates the two systems. This can involve changing the units of measurement, using rotation or translation matrices, or using geodetic calculations.
3. What are the most commonly used coordinate systems?
The most commonly used coordinate systems include Cartesian (x, y, z), polar (r, θ, φ), and geographic (latitude, longitude, altitude). Other examples include UTM (Universal Transverse Mercator), State Plane Coordinate Systems, and Global Positioning System (GPS) coordinates.
4. How does the Earth's curvature affect the relationship between coordinate systems?
The Earth's curvature affects the relationship between coordinate systems in two main ways. Firstly, it causes distortions in the shape and size of objects when projected onto a flat surface. Secondly, it requires the use of geodetic calculations to accurately measure distances and angles on the Earth's curved surface.
5. Can two coordinate systems have the same origin point?
Yes, two coordinate systems can have the same origin point. In fact, many coordinate systems are designed to have their origin at a specific location, such as the equator or a specific landmark. However, the orientation and units of measurement may differ between the two systems.
