Relationship between two entire functions
In summary, the Liouville's theorem states that if the function h is bounded on the interval [a, b], then it must be constant.
Bingk1
Hello, this was another question on the exam which I wasn't sure about:
Let [TEX]f[/TEX] and [TEX]g[/TEX] be entire such that [TEX]|f(z)| \leq |g(z)| \ \forall z \in \mathbb{C}[/TEX]. Find a relationship between [TEX]f[/TEX] and [TEX]g[/TEX].
I'm kinda lost on this one...
Thanks!
Thanks!
A consequence of the Liouville's theorem is that if $\displaystyle |f(z)|\le |g(z)| \forall z \in \mathbb{C}$, then it must be $f(z)=\alpha\ g(z)$ for some complex $\alpha$...
Kind regards
$\chi$ $\sigma$
Hi, that's actually what I got, but I'm pretty sure I got it the wrong way. I don't remember exactly what I did (the exam wasn't returned to us), but my method involved the Maximum Modulus Principle (sort of like applying Liouville's on open balls).
How exactly is that a consequence of Liouville's theorem?
I can see that for the case of g being constant, then f should be constant, so g will be a multiple of f. What about for when g is non-constant?
From what I can recall, what I think I did was I said that in an open ball, f and g attain their maximum modulus on the boundary and the modulus of g will be greater than that of f at that point in the boundary. This will happen for any open balls. So, if we consider two balls with the same center, and let the radius of one approach the other, and see what happens to the modulus of f and g at that boundary, it should turn out that g is a multiple of f. Is this sort of right?
If You consider the function...
$\displaystyle h(z)=\frac{f(z)}{g(z)}$ (1)
... then, because is $\displaystyle |f(z)| \le |g(z)|$ h(*) is bounded. That means that all the zeroes of g(*) must be also zeroes of f(*) and h(*) is entire, so that h(*) for the Liouville's theorem must be a constant that we call $\alpha$...
Kind regards
$\chi$ $\sigma$
Thank you! I didn't think to consider the function h ... but it should've occurred to me.
FAQ: Relationship between two entire functions
What is the definition of an entire function?
An entire function is a complex-valued function that is defined and analytic over the entire complex plane.
How is the relationship between two entire functions determined?
The relationship between two entire functions can be determined by examining their common zeros and poles, as well as their behavior at infinity.
Can two entire functions have the same zeros and poles?
No, two entire functions cannot have the same zeros and poles. If two entire functions have the same zeros and poles, then they are identical.
What is the difference between a meromorphic function and an entire function?
A meromorphic function is a complex-valued function that is defined and analytic everywhere except for a set of isolated poles, while an entire function is defined and analytic over the entire complex plane.
How does the growth rate of entire functions affect their relationship?
The growth rate of entire functions can provide information about their relationship. For example, two entire functions with different growth rates cannot be identical.
