Relationship Between Wind and Pressure
In summary, the pressure caused by a wind blowing against a structure increases as the square of the wind velocity due to the conversion of kinetic energy to pressure energy as the wind stagnates against the surface. This can be derived using a simplified form of the Bernoulli equation for incompressible flow.
Mykhalo P
I read in a book that the pressure caused by a wind blowing against a structure increases as the square of the wind velocity. I cannnot logically understand how that makes sense, and I can't think of any equation to support it. Can somebody please shed light, conceptually or mathematically, as to why this statement holds true? I appreciate any and all help.
It's empirically derived, for a certain range of speeds. Conceptually in a simplified model: Twice the speed means twice the number of particles loose twice the momentum in the same time, so four times the momentum change in the same time.
it also has to do with KE . KE will go up with the square of speed. those molecules of air at higher speed have a squared weight attached to them.
KE = 1/2mv^2. the rate of doing work of moving the air molecules out of the way, goes up with the square of speed. and another mind bogler, is that say you are in a car and have reached the top speed of the car at 100mph and it has 100hp. to go 200mph will take the cube of the speed difference, so it will take 8 tiimes the HP to go 200mph. why? because aero resistance goes up with the square of speed and HP is force times speed. walla... 8x the power for 2x the speed
zanick said:
[...]will take the cube of the speed difference
Cube of the speed, not the speed difference. The incremental power requirement for, say, a 1 mph speed difference goes as the square of the current speed.
1013 - 1003 ~= 30,000
2013 - 2003 ~= 120,000
With the cube of speed: F ~ v2 so F * v = P ~ v3
pressure is due to FORCE on the wall, force is equal to rate of change of momentum, momentum = mass x velocity,
If you double the velocity you double the mass hittting the wall per second and therefore, with double the velocity the force is 4 x bigger.
force is proportional to v2
sorry, meant "cube of the speed change" not difference. it changes by factor of 2, power changes by 2^3 or 8 times)
As this article shows:
https://en.wikipedia.org/wiki/Stagnation_pressure
the stagnation pressure resulting from wind blowing perpendicular to a flat surface can be derived using a simplified form of teh Bernoulli equation for incompressible flow. Bernoulli gives stagnation pressures, which vary as wind speed squared, and the resulting force is F = Pstag * A.
As others have pointed out, the kinetic energy in the wind flow has been converted to pressure energy as the wind velocity goes to zero, or stagnates, against the surface it is striking.
FAQ: Relationship Between Wind and Pressure
What is the relationship between wind and pressure?
The relationship between wind and pressure is that wind moves from areas of high pressure to areas of low pressure. This is known as the pressure gradient force. The greater the difference in pressure between two areas, the stronger the wind will be.
How does wind affect pressure?
Wind can affect pressure by causing changes in air pressure. As wind moves from areas of high pressure to areas of low pressure, it can cause changes in pressure patterns. This can lead to changes in weather conditions.
What factors influence the relationship between wind and pressure?
Several factors can influence the relationship between wind and pressure. These include the temperature, humidity, and topography of an area. Additionally, the rotation of the Earth and the Coriolis effect can also play a role in the direction and strength of winds.
How do scientists measure the relationship between wind and pressure?
Scientists use instruments called barometers to measure air pressure, and anemometers to measure wind speed and direction. These measurements are then used to understand the relationship between wind and pressure and make predictions about future weather patterns.
What are the practical applications of understanding the relationship between wind and pressure?
Understanding the relationship between wind and pressure is important for a variety of practical applications, such as predicting weather patterns and forecasting severe storms. It is also crucial for industries such as aviation and marine transportation, where accurate knowledge of wind and pressure conditions can impact safety and efficiency.
