Relationship between work and force
In summary, the conversation discusses a windmill with no friction and a weight attached to its pulley. The windmill is initially spinning at 100 RPM due to the constant wind speed, but the addition of the weight affects the acceleration and speed of the windmill. The conversation also considers different scenarios, such as the weight being attached while the windmill is already spinning or starting at rest, and the impact of gear ratios on the turbine's speed and the weight's velocity.
sean39
This is just a question that has been bothering me. I am not a student of physics, which is probably clear from my question. Hope it at least makes sense:
  • You have a windmill with no friction.
  • The wind is blowing at a constant speed causing the windmill to spin at 100 RPM.(a)
  • The windmill is hooked up to a pulley with no friction with a 1 kg weight attached.
  • The energy transfer from the wind to the windmill to the pulley occurs with 100% efficiency.
  • Now that the weight is attached, enough constant force is exerted by the wind on the windmill to raise the weight 1 m / sec. (1 joule of work)
What happens? Does the windmill slow down because of the weight? Seems like if the weight was attached while the windmill was already spinning, 100% of the force of the wind would be transferred to the pulley. But the windmill would just keep spinning anyway since there's no friction.
But if the windmill started out at rest when you hooked up the pulley, I don't know what would happen.
Would it take longer to lift the weight since the force of the wind is being used for both purposes, lifting the weight and accelerating the windmill blades? So is the weight raised at 0.5 m/ sec until the windmill gets up to 100 RPM, and then start going up at 1m / sec? Or something like that?
(a) If the windmill has no friction, then it would spin perpetually at 100 RPM from a single gust. So I guess the amount of power exerted by that first gust to get the windmill from rest to a speed of 100RPM is all that matters. After that, the windmill would just spin at the same rate whether the wind continues to blow or not?
Yes, the windmill speed would initially be zero and then, once the blade lock was released to allow it to spin, its speed would increase. The acceleration would decline in order to make the speed asymptotically approach one that lifts the mass at 1m/s.
Initially all the work of the wind will go to accelerating the mass. As the speed increases, the proportion devoted to that task decreases as more of the work is devoted to working against gravity. The proportion devoted to acceleration will decline towards zero but never reach it. The mass's velocity will asymptotically approach 1m/s but never reach it.
With the weight, the windmill won't get to 100 RPM (nor will it asymptotically approach that speed). 100 RPM is the speed at which the wind exerts no torque on the windmill (equilibrium for a friction less windmill). With the weight it will asymptotically approach a speed where the aerodynamic torque balances the torque from the weight (less than 100 RPM).
Ok. Thank you.
What is the formula to determine the rate of acceleration? Does this mean with zero weight attached to the.blade it will asymptotically approach 100 rpm? What about with a 2 kg weight?
https://en.wikipedia.org/wiki/Angular_acceleration#Equations_of_motion
Weight attached to the blade? I thought the weight is on a rope around a pulley.
Will go slower than 1kg.
You are going to have some sort of gear ratio (probably adjustable) between the turbine and the weight. The gear ratio will lock a ratio between the angular velocity of the turbine and the velocity of the weight. If you have twice the weight with the same gear ratio, the turbine will be slower (or may even go backwards). But if you double the gear ratio, then you can have the turbine spin as fast as before (with 1kg weight), but the weight will move up half as fast.
Related to Relationship between work and force
1. What is the definition of work and force?
The scientific definition of work is the product of force and displacement, where force is the amount of energy exerted on an object and displacement is the distance the object moves in the direction of the force.
Force, on the other hand, is a push or pull on an object that can cause it to move, change direction, or change shape.
2. How are work and force related?
Work and force are directly related, meaning that an increase in force will result in an increase in work, and vice versa. In other words, the more force that is applied to an object, the more work is done on that object.
3. What is the formula for calculating work?
The formula for calculating work is W = F x d, where W is work, F is force, and d is displacement. This means that work is equal to the amount of force applied multiplied by the distance the object moves in the direction of the force.
4. How does the direction of force affect work?
The direction of force does affect work, as work is only considered to be done when the force and displacement are in the same direction. If the force is applied in a different direction than the displacement, then no work is done on the object.
5. What are some examples of work and force in everyday life?
Some examples of work and force in everyday life include lifting weights, pushing a car, and pulling open a door. In each of these scenarios, force is being applied to an object, resulting in work being done on that object.
  • Mechanical Engineering
  • Mechanics
  • Electrical Engineering
  • Mechanics
  • Mechanics
