Relationship of spring constant and torsion constant?
In summary: The sections near the bend will experience more torsion than those near the center of the spring. There is no simple relationship between the spring constant and the outer diameter of the spring.
NoviSad
I'm trying to find a relationship between spring and torsion constants for an experiment but am not sure what it is and am struggling to find it.
Torque = Torsion Constant * Angle of Twist
Force = Spring Constant * Extension
Shear Modulus = Force*Length/Area*Extension
I have absolutely no idea.
The spring constant and the torsion constant measure different actions on a body. The spring constant is fundamentally related to the axial compression of the spring, while the torsion constant measures the effect of twisting on the spring.
AFAIK, the two constants are not related.
The variables involved are orthogonal to one another (##r## vs ##\phi##), so they are independent of one another.
If you are asking about a straight wire, the two material properties (Young's modulus and shear modulus) are independent of each other. There is a formula that connects E, G, and Poisson's ratio for isotropic materials, but any two of those three constants are independent.
If "spring constant" means you are talking about a coil spring, there is a complicated relation between the extension and torsion stiffness which involves the geometry of the spring (turns per unit length, diameter of the wire, and diameter of the coils) as well as the shear modulus of the material. But most real-world springs are meant to be used either in extension or in torsion, but not both together.
Strange, I was seemed to be made to believe there definitely was one. Talking about a rubber band by the way.
1. Homework Statement
Does extension affect the torsion constant in any way?
Known data: Extension, Force, Time Period
2. Homework Equations
Time Period of a Torsion Pendulum = 2PI sqrt(Moment of Inertia/Torsion Constant)
3. The Attempt at a Solution
Having a very hard time, unsure what to do to figure this out, even with the data.
what is the relationship between the spring constant and the outer diameter of the spring?
The terminology for springs is confusing.
An everyday helical spring under tension or compression works by torsion of the material. As you pull the ends and stretch out the spring, the wire undergoes torsion. If a spring of N coils, fully closed when relaxed, is pulled completely straight (and the ends of the wire not allowed to rotate the applied load) it will have a net strain of 2πN along its length.
To figure out the algebra, it might be easiest to start with a simple loop of wire, cut at some point. If the two ends of the cut are displaced from each other by one wire thickness they now form one loop of a fully compressed spring. Through what angle will the two cut ends have turned on their core axes?
There are also "torsion springs". In this case, a torque is applied along the main axis of the helix, tightening or expanding the spring diameter. As far as the wire is concerned, this is a bending moment, not torsion. See https://en.wikipedia.org/wiki/Torsion_spring.
A third way to use a helical spring is to bend it sideways. This again produces torsion in the wire, but unevenly.
FAQ: Relationship of spring constant and torsion constant?
1. What is the relationship between the spring constant and torsion constant?
The spring constant and torsion constant are directly related to each other. This means that as one increases, the other also increases. This relationship is known as Hooke's Law.
2. How do the units of measurement for spring constant and torsion constant differ?
The units of measurement for spring constant are typically in Newtons per meter (N/m), while the units for torsion constant are typically in Newton-meters per radian (Nm/rad).
3. Can the spring constant and torsion constant be used interchangeably?
No, the spring constant and torsion constant are specific to different types of systems. The spring constant is used to describe linear systems, while the torsion constant is used to describe rotational systems.
4. What factors affect the values of spring constant and torsion constant?
The values of spring constant and torsion constant are dependent on the material properties of the spring or torsion bar, such as its length, diameter, and material composition. Temperature and external forces can also affect these constants.
5. How do the spring constant and torsion constant affect the behavior of a system?
The spring constant and torsion constant determine the stiffness of a system. A higher spring constant or torsion constant means that the system is more resistant to changes in its position or orientation, while a lower constant indicates a more flexible system.
