- #36
Googl
- 111
- 1
Andrew Mason said:Stop right there. A resistor does not provide voltage. A battery provides voltage, which is energy per unit charge. A resistor uses energy. The energy it uses is the potential drop (change in potential energy/unit charge) x charge passing through the resistor. The rate of energy use (power consumption) is the potential drop x current (charge/unit time).
AM
I understand that I just did not find the right words at the time.
So having DROP at the end of voltage is very significant (voltage drop). A circuit will have 20V across it without a resistor. When a resistor is added a voltage drop will occur across the resistor which will be directly proportional to the size of resistance. So the greater the resistor resistance the greater the voltage drop across the resistor that occurs.
I think I did not have enough confidence in what the quantity of voltage actually is, which is the difference of two points electrical potentials. So when a voltmeter is set at two terminals it will measure the potential difference between the two terminals, so the electrical potential at one terminal could be 5V while the other 2V and the voltage would be 5V-2V which is equal to 3V.
