Relationship of voltage and resistance
In summary, the conversation discusses the relationship between voltage and resistance, particularly in the context of a variable resistor. It is established that voltage drop across a resistor is directly proportional to the resistance, as described by Ohm's law. However, this relationship is dependent on the context and may not hold true in all situations, such as when the voltage supplied is constant. The conversation also delves into the concept of internal resistance in power sources and the limitations of increasing current. Ultimately, it is advised to focus on the defined ratio of resistance as a means of understanding the relationship with voltage.
  • #36
Andrew Mason said:
Stop right there. A resistor does not provide voltage. A battery provides voltage, which is energy per unit charge. A resistor uses energy. The energy it uses is the potential drop (change in potential energy/unit charge) x charge passing through the resistor. The rate of energy use (power consumption) is the potential drop x current (charge/unit time).
AM
I understand that I just did not find the right words at the time.
So having DROP at the end of voltage is very significant (voltage drop). A circuit will have 20V across it without a resistor. When a resistor is added a voltage drop will occur across the resistor which will be directly proportional to the size of resistance. So the greater the resistor resistance the greater the voltage drop across the resistor that occurs.
I think I did not have enough confidence in what the quantity of voltage actually is, which is the difference of two points electrical potentials. So when a voltmeter is set at two terminals it will measure the potential difference between the two terminals, so the electrical potential at one terminal could be 5V while the other 2V and the voltage would be 5V-2V which is equal to 3V.
  • #37
This is not correct. An electric potential s applied to the resistor by the voltage source (battery). The amount of resistance placed in the electric field created by the voltage source (ie. the load resistance to which the voltage is applied) does not affect the magnitude of this potential difference. The resistor material provides charges that move in response to the electric field created by the electric potential. The greater the resistance, the fewer charges that flow in response to the electric field. The potential energy of charges present in that field (ie. in the resistor having uniform resistance per unit length) decreases in a linear fashion as one goes from one end of the resistor to the other, from 20 Joules/coulomb at one end down to 0 at the other.
This is correct but somewhat misleading. Voltage (potential difference) is potential energy per unit charge at one point relative to another. Potential difference at a point is always measured relative to some other point. So we can only talk about 5V or 2V in relation to TWO points, not one.
Voltage does NOT depend on the size of the load resistance to which the voltage is applied (unless the load resistance is in the same order of magnitude as the internal resistance of the voltage source).
Think of Niagara Falls. The "potential difference" is determined only by the height of the falls. Whether I run a garden hose from above the falls to a point at the bottom to run a lawn sprinkler, or a 5 metre diameter channel to a turbine generator, the potential drop for both loads is the same.
AM
  • #38
Googl said:
I am trying to understand the relationship between voltage and resistance.
Ohm's law: V=IR
They are proportional to each other given a fixed current.
  • #39
@Googl
I'm afraid that you started this thread with a question that used the 'wrong' words with not enough context for people to understand what you were really getting at. You then drew a diagram which (strictly) was not of the circuit you were discussing - which further confused everyone.
This sort of thing would not occur if you were prepared to get information from a standard text, rather than trying to follow your own line of enquiry. If you had read around a bit then you would have known that a variable resistor is not a potential divider and that a 'potentiometer' is a three terminal device that can be connected in various ways. You would also have found the (very elementary) formula for the way a potential divider works and your question would have been answered without all this confusion.
I don't want just to be grumpy about this but there are better ways of getting to grips with electronics - which involve taking information as it is normally taught. It is presented as it is because that method works.
But don't stop asking relevant questions!
  • #40
we use wires
I think that we can not say r is equal to 20ohm volt will be 20 volt ,because we use wires to connect resistance and battery and these wires's resistance are not zero hence they take voltage,theoretical we say v=I.r and if I has constant value then volt and ohm are proportional but in there we don't condider wires's resistance and you guess that in real this is not like that
  • #41
There are remarkably few 'electronics' circuits in which you actually need to take into account the resistances of connecting wires. For a long mains supply cable or a short lead from battery to car starter motor, the wire resistance is very relevant but, in most cases, you really don't need to bother. Even when you do, you just need to treat the connecting wires as additional resistances in the circuit and follow the formula through.
I do not understand why people are trying to describe what happens in a circuit in words when the tried and tested formulae work so well. At this level, electrical theory is really not suited to 'verbal' descriptions. Just learn and use the formulae guys your alternative, 'chatty', analysis is not revealing anything significant about the Physics of what's happening.
  • #42
As I understand,Current is just the magnitude of the amount of electrons and voltage is a pressure force (potential difference) which causes for the flow of electrons.. Without this pressure(voltage) there is no current/electron flow...And resistance is something (like a property of a material depending upon temperature) which opposes the flow of electrons.
Actually resistance is not getting varied unless there is change in temperature or length or the cross sectional area...
Mathatically resistance is just the proportionality 'constant' to derive the Ohm's law. and it is an independent from voltage or current.
