- #36
- 10,356
- 1,531
I think I have a resolution, more or less, though it's not terribly well documented at this point.
We can formally use the above vector potential to show that the integral of the E-field around any closed curve in which the line charge is at rest is zero. This is in accord with the induction law, that the integral of E around any curve is equal to the rate of change of magnetic flux.
I've been lazy and haven't gone through the math in detail on the case where there is a line current (rather than a line charge) but I'm pretty confident that one will find that around a closed loop, there is a magnetic flux, and if you move the loop correctly you can get it to change. I'm confident that Maxwell's equations will work and give that the integral around the curve of E is nonzero and is equal to the rate of change of the magnetic flux, which is also nonzero.
[add]I've also been lazy and assumed that the "loop of wire" has a high enough resistance that it doesn't affect the field configuration, rather than a zero resistance, which would mean placing the charges on the wire correctly to make the electric potential constant throughout the wire. Mainly because it's so much easier to do, and we can tell which way the current "wants to flow" if there is a high resistance, we don't need to get into that level of detail.Where does this leave us on a practical level? Formally, we are saying that due to the relativity of simultaneity, we are integrating around a different curve. But what about the questio about whether or not the light lights up? I submit that a good part of the answer is that while Maxwell's equations are frame independent, the constituitive equations, relating the material properties, ARE frame dependent.
I found one reference on this point which is, alas, behind a paywall. There's probablly more.
http://www.springerlink.com/content/n726472450j38731/
"On the frame dependence of electric current and heat flux in a metal
Zur Bezugssystem-Abhängigkeit des elektrischen und des Wärmestroms in einem Metall"
The other part of the issue I think is the issue of proving what's called the "lumped circut approximation". One of my old E&M books had a formal proof, but I don't recall where it wandered off to. At any rate, the point is that in the approximation, the current anywhere around a loop will be constant, if and only if you can ignore the capacitive effects that allow charge to accumulate at "nodes".
This follows from the conservation of charge.
IF we had a wire with a current rather than a line charge, I'd feel comfortable in ignoring the capacitive effects. With the really high electric fields that an un-neutralized line charge will have, I'm not sure if the capacitive effects can be ignored. I'm not terribly interested in modelling them (the capacitive effects) in detail, but it doesn't see like a "big mystery" to me, just a lot of work.
So my basic resolution is that while Maxwell's equations are frame independent, the behavior of the wire isn't. To use familiar analysis techniques, its important that we analyze the problem in the frame of the wire - or at least a frame where the wire is moving very slowly compared to the speed of light.
