Relative distances (motion problem) --
  • Thread starter christian0710
  • Tags
    Relative
In summary, the problem involves a collision where an automobile traveling at 50 km/h decelerates at a constant rate of 200 m/s^2. A passenger not wearing a seat belt crashes into the dashboard, with a distance of 0.60 m between them before the collision. The solution involves calculating the time at which the passenger's face hits the dashboard, as this is when the damage is done. The answer is a relative velocity of 15.6 m/s.
christian0710
409
In a collision, an automobile initially traveling at 50 km/h decelerates at a constant rate of 200 m/s^2. A passenger not wearing a seat belt crashes against the dashboard. Before the collision, the distance between the passenger and the dashboard was 0.60 m. With what speed, relative to the automobile, does the passenger crash into the dashboard? Assume that the passenger has no deceleration before contact with the dashboard.
+ [/B]
The equations for the cars decceleration, velocity and distance traveled are:
a=-a=200m/s^2
v=--a*t +V0
X(t) = -a/2 * t^2 +V0*t 3.The attempt at a solution
we change velocity into m/s
50km/h = 50*1000/60^2 = (125/9 ) m/s
The time at which the car comes to a halt is when velocity = zero
0= a*t –V0
t=V0/a = (125/9)/200 = 5/72sec
The distance the car traveled in that time is
X(5/72) = -200/2 * (125/9)^2 +(125/9)*(5/72) = 0.48 meters
The speed of the passenger must be
0,06m/5/72sec = 8.64m/s
The speed of the car must be
0.48/(5/27) = 6.9m/s
The difference between 8.64 and 6.9 ( I assume is what is meant by relative distance? ) can impossible be 15.6 m/s which is the answer.
Help Is a ppreciated.
The solution hinges on calculating details about when the passenger's face "overtakes" his car, because until that happens there is no damage incurred to his head. The time the car takes to come to a standstill has no real relevance, the damage has been done long before the car halts, usually.
The question is asking for relative velocity, not relative distance.
The problem doesn't state that the car remains at a halt when its speed reaches zero. If you find that the car reaches zero speed before the passenger hits the dashboard then I suppose you'll have to make an assumption about any continuing motion of the car after that instant.
Related to Relative distances (motion problem) --
1. What is relative distance?
Relative distance refers to the distance between two objects or points, taking into account their changing positions in relation to each other. It takes into consideration both the distance traveled and the direction of motion.
2. How is relative distance different from absolute distance?
Absolute distance is the total distance between two objects or points, regardless of their changing positions. Relative distance, on the other hand, takes into account the movement of the objects and their changing positions in relation to each other.
3. What is a motion problem?
A motion problem is a problem that involves using equations and concepts from physics to solve for unknown variables related to motion, such as distance, time, and velocity.
4. How do you calculate relative distance?
To calculate relative distance, you need to know the initial positions of the objects, their velocities, and the time period over which their positions are being measured. You can then use the formula relative distance = (velocity of object 1 - velocity of object 2) x time to calculate the relative distance between the objects.
5. What are some real-life examples of relative distance?
Some examples of relative distance in everyday life include measuring the distance between two moving cars on a highway, tracking the distance between two runners in a race, or calculating the distance between two planets in our solar system as they orbit around the sun.
