Flatliner
- 12
I recently got heavier into cigar smoking and want to start storing cigars at home in a humidor. Like most things that become a sort of hobby of mine, I research the hell out of my new fascination.
So while learning about humidors, I discovered that the cigar community is split on whether or not the relative humidity the humidor is kept at should change based on temperature. Below I’ll paste two differing opinions along with the rationales:
RH shouldn’t change with varying temps:
RH should change with varying temps:
So, I come to the Physics Forums for the science smackdown. Who is right?
http://en.allexperts.com/q/Cigars-2143/2009/9/Absolute-vs-Relative-humidity.htmThe modern myth of varying humidity with temperature is based on an entirely false premise. Cigars don't care about absolute moisture content. They need just enough moisture to keep the tobacco pliable, but not so much to swell it. This occurs at 70-73% REGARDLESS of temperature.
Tobacco should be kept at a relative humidity which just keeps the leaves pliable without swelling them. Since that pliability is based on the interaction of the cellular membranes with the air surrounding them, *relative humidity*, not absolute moisture content is what's important. This isn't chemistry, it's mechanics - on a cellular level. Ideally, the correct point is 70-73% regardless of temperature. At 70% relative humidity (a measure which by definition is independent of temperature) cigar leaves become pliable without swelling. at 75% or higher, the cells begin to swell. at 68% or lower, they can become brittle. These points are regardless of the ambient temperature or the absolute moisture content.
http://vigilantinc.com/cigarhumidors/humidity-and-temperature.phpThe most common rule of thumb for your cabinet humidor climate is commonly referred to as the 70/70 rule. Keeping a temperature of 70°F and a RH of 70%, means that you will have the right level of AH or water vapor pressure to store your cigars. Each temperature has a corresponding RH level that helps maintain the correct AH to keep your cigars aging nicely, as displayed in the chart below. If your temperature changes from 70°F to 72°F the RH should read 65% in order to keep an AH comparative to the standard of 70/70. There are exceptions to the rule, though. Once the temperature goes below 60°F, there is no corresponding RH level that will give you an appropriate AH. The air simply can not hold that much moisture.
