Relative Humidity Inside a not so Perfectly Sealed Housing
In summary, the conversation discusses a problem with a sealed metal housing that is being purged with dry air in order to maintain a specific dew point. However, the seals on the unit are not perfect and allow a known amount of water to enter per day. The temperature and pressure of the environment inside the housing is constant, and the question at hand is what the relative humidity would be at the end of one day. The individual asking for help would prefer formulas and theory to be used instead of psychrometric charts, and suggests using nitrogen or other gases to avoid moisture ingress.
Euan Foster
Hey all,
As environmental physics isn't my forte, I have a problem that has been annoying me for about a month now at work and I am still getting no where with it... so any help with this head ache is much appreciated. The problem at hand is as follows.
A sealed metal housing is purged with 100% dry air until the dew point of the internal environment is -40 deg C. However, the seals on the unit are far from perfect and let in a known amount of water per day for a given environment, call it 1E-6 grams of water per day. The volume of the internal environment contained within the housing is known to be 0.003 m^3. The temperature and pressure of the environment is constant at 30 deg C and 101325 Pa.
At the end of one day, what is the relative humidity inside the metal housing?
I would prefer if any answers to this use formulas/theory as much as possible and refrain from using psychometric charts and steam tables. I am trying to repeat this over a large range of values on excel/matlab so repeat ability is key... unless someone knows of any psychometric chart resource already tabulated so that values can be searched for?
I am probably missing something terribly simple, but as mentioned any help will be much appreciated.
Looking forward to hearing any responses
Regards,
Euan Foster
There are a number of psychrometric (please remember to add that "r") calculators available on the web. Some are from educational or professional organizations. You could directly ask them how they did it. My guess is that they used curve matching to derive formulas for the % humidity curves. Temperature is easy, all straight lines.
Hi Euan
Welcome to PF :smile:
one obvious solution would be to purge with something other than dry air and to keep it under pressure
Nitrogen is commonly used as are a couple of other gasses and if their pressure inside the container is
higher than atmospheric, then you are not going to have a moisture ingress problem.
Periodic checks of container pressure will have to be done. As you said, your seal and you will find few others are perfect
and occasional repressurisations will be required
something to consider
cheers
Dave
Related to Relative Humidity Inside a not so Perfectly Sealed Housing
1. What is relative humidity?
Relative humidity is a measure of the amount of water vapor in the air compared to the maximum amount of water vapor that the air can hold at a specific temperature. It is expressed as a percentage.
2. Why is relative humidity important in a not so perfectly sealed housing?
Relative humidity is important in a not so perfectly sealed housing because it can affect the indoor air quality and comfort level of the occupants. High humidity levels can lead to mold growth, while low humidity levels can cause discomfort and respiratory issues.
3. How does relative humidity impact the materials inside a not so perfectly sealed housing?
Relative humidity can impact materials inside a not so perfectly sealed housing by causing them to expand or contract, leading to potential damage or degradation. Materials such as wood, paper, and fabric are particularly sensitive to changes in humidity.
4. What is the ideal relative humidity for a not so perfectly sealed housing?
The ideal relative humidity for a not so perfectly sealed housing is between 30-50%. This range is considered to be comfortable for humans and also helps to prevent mold growth and damage to materials.
5. How can the relative humidity inside a not so perfectly sealed housing be controlled?
The relative humidity inside a not so perfectly sealed housing can be controlled through the use of a dehumidifier or humidifier, proper ventilation, and sealing any air leaks. It is also important to monitor the humidity levels regularly to ensure they stay within the ideal range.
  • General Discussion
