Relative motion (2 arrow shot up find meeting distance)
In summary: So the equation becomes:u1*t + 3*u1 - 0.5*g*t^2 - 0.5*(6*t + 9) = u2*t - 0.5*g*t^2Simplifying:u1*t + 3*u1 - 3*t - 4.5 = u2*tSubtracting u1*t and 3*u1 from both sides:-3*t - 4.5 = (u2 - u1)*tSolving for t:t = -4.5 / (u2 - u1)Plugging in the given values for u1 and u2:t = -4.5 / (60 -
GregR
Two arrows are fired straight up. The first is at 40 m/s and the second at 60 m/s and 3 seconds after arrow one. At what hieght will the arrows meet in the air.
s=ut+1/2 at^2
s1=s2
t2=t1+3
u1(t2+3)+1/2a(t2+3)^2=u2t2+1/2at2^2
Hi GregR, welcome to PF.
Your approach is correct.
But
t2=t1+3 it should be t1=t2+3.
In the equation you have substituted correctly.
Now proceed.
So then:
u1t2+3u1+.5at22+4.5a=u2t2+.5at22
u1=40m/s
u2=60m/s
a=-9.81m/s2
The .5at22 on each side should cancel each other out leaving:
u1t2+3u1+4.5a=u2t2
Solving:
40t2+3(40)+4.5(-9.81)=60t2
40t2+120-44.145=60t2
20t2=75.855
t2=75.855/20
t2=3.79275 seconds
If I use this as the time and recalculate the distance for each arrow it doesn't jive.
Through trial and error I found the meeting time to be 1.5345 seconds at a distance of 80.52 meters from the ground.
Not sure if I'm missing something or its just a minor error on my part.
Your calculation is wrong.
The equation will be
u1(t+3) - 0.5*g*(t+3)^2 = u2*t - 0.5*g*t^2
Simplify the equation and solve for t.
Using this formula:
From this I simplified as follows:
u1t +3u1-0.5*9.81*(t2+9) = u2*t - 0.5*9.81*t2
u1t +3u1-4.905*(t2+9) = u2*t - 4.905*t2
u1t +3u1-4.905*t2-4.905*9 = u2*t - 4.905*t2
The -4.905*t2 on both sides should cancel out leaving.
u1t +3u1-44.145= u2*t
Inserting u1=40m/s and
u2=60m/s
40*t + 30*40 - 44.145 = 60*t
40*t + 120 - 44.145 = 60*t
75.855 = 60*t - 40*t
20*t = 75.855
t = 75.855 / 20
t = 3.79275
I wrote it up step by step and got the same results.
Not sure where I'm going wrong here.
Please let me know.
Thanks
(t+3)^2 = t^2 + 6*t + 9
FAQ: Relative motion (2 arrow shot up find meeting distance)
What is relative motion?
Relative motion is the study of the motion of objects in relation to each other. It takes into account the movement of both objects and how they interact with each other.
How is relative motion different from absolute motion?
Absolute motion refers to the motion of an object in relation to a fixed point in space, while relative motion takes into account the motion of two or more objects in relation to each other.
What is the formula for calculating relative motion?
The formula for relative motion is: Relative Velocity = Velocity of Object A - Velocity of Object B.
Can relative motion be applied to both linear and rotational motion?
Yes, relative motion can be applied to both linear and rotational motion. It is a fundamental concept in understanding the motion of objects in both types of motion.
How is relative motion used in real-world applications?
Relative motion is used in a wide range of real-world applications, such as navigation, astronomy, and transportation. It is also used in sports, such as calculating the trajectory of a ball in motion.
