Relative motion and displacement
In summary, a man walks 600m east 47 degrees north, then 500m north 38 degrees west, then 300m west 29 degrees south, and finally 400m south 13 degrees east. To find the resultant displacement, we must place the protractor's 0 degree mark at east and measure up 47 degrees counterclockwise from the positive x (east) axis. This will give us the angle for the final displacement.
Scarlet_pat
44
a man walks 600m [E47 degree N] then 500m [N38 degree W] then 300m [W29degree S] and finnally 400m [S13degree E]
find this resultant displacement.
my problem is .. [E47 degree N] ... does that mean i must put the protractor's 0 degree at East or north ?
[E 47 degrees N] implies the angle is 47 degrees north of east , so, yes, you place the protractor's 0 degree mark at east, then measure up 47 degrees counterclockwise from the positive x (east) axis.
ok thank you very much .. .. :) :) :)
FAQ: Relative motion and displacement
What is relative motion?
Relative motion refers to the movement of an object in relation to another object or observer. It takes into account the perspective of the observer and how their movement affects the perceived motion of the object.
How is relative motion different from absolute motion?
Absolute motion is the actual physical movement of an object in space, regardless of an observer's perspective. Relative motion, on the other hand, takes into account the observer's frame of reference and how their own motion affects the perception of the object's motion.
What is displacement?
Displacement is the change in position of an object in a specific direction. It is a vector quantity, meaning it has both magnitude (distance) and direction.
How is displacement different from distance?
Distance is the total length traveled by an object, while displacement is the change in position from the starting point to the ending point. Distance is a scalar quantity, meaning it only has magnitude and no direction.
How can relative motion and displacement be used in real-world applications?
Relative motion and displacement are important concepts in understanding the movement of objects and how they interact with their surroundings. They have practical applications in fields such as physics, engineering, and navigation, where precise measurements and calculations of motion are necessary.
