- #36
JesseM
- 16
What do you mean "restriction"? Light waves were assumed to be vibrations in the ether just like sound waves are vibrations in air. In the rest frame of the air, all sound waves move at the same speed regardless of the speed of the emitter, so it was assumed light waves worked the same way (the speed of vibrations in any medium depends on physical properties of the medium like density and rigidity). And if you're moving at some speed v relative to the rest frame of the air, then in your frame sound waves will move at s + v in one direction and s - v in the opposite direction, and similarly it was assumed that if you were moving at v relative to the ether, you'd measure light waves to move at c + v in one direction and c - v in the other. Since Maxwell's laws predict that light waves always move at c, it was assumed Maxwell's laws would only work exactly in the rest frame of the ether, in other frames they'd have to be modified by a Galilei transformation.DewaldS said:Question: The 'ether' for which the MM device was actually designed. I would suppose the ether was up to some point in history used by some scientist to explain how light could 'move' through space? Why would the relative movement of the light through the ether be met by any restriction? I would suppose this is an energy consideration, but I would like to know, please.
