Relative Motion - River/Boat problem
To solve the river/boat problem, two equations must be established: one for the boat's speed downstream with the current and one for upstream against it. The total distance traveled downstream and upstream is the same, allowing for a relationship between the boat's speed and the river's current speed. The key is to use the time taken for each leg of the journey to create equations that incorporate both speeds. By solving these simultaneous equations, the speed of the river can be determined accurately. Understanding the relative motion concept is crucial for finding the correct solution.
Kosmos77
A boat takes 2.80 hours to travel 30.0 km down a river, then 4.50 hours to return. How fast is the river flowing
Vac = Vab + Vbc
I wasn't quite sure how to use the formula that the professor gave us which is above for this particular problem. The way I see it, since the problem doesn't say their is a change in acceleration, I'm thinking the speed of the boat IS the speed of the river seeing as it is saying "down" a river... so I just took 30 / 2.8 which gives me the speed of the boat but... It's not the answer.
There are a couple of steps involved here:
1. Set up two equations for the speed of the boat when it is going with and against the current.
2. Set up an equation in which you state that the distance traveled in both cases in exactly the same.
3. Find a relationship between the boat speed and the current speed using the above.
4. Use the fact that they give you the distance traveled to your advantage. With this, you can set up another equation relating the boat and current speed. With two equations and two unknowns, you can finish the problem.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up will act downwards and maximum static friction will act downwards Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
