Relative velocity and conservation of momentum
The discussion centers around solving a problem involving an elastic collision between two particles of different masses moving toward each other. The initial equations based on conservation of momentum and relative velocity are debated, with participants emphasizing the need for both momentum and kinetic energy conservation in elastic collisions. The concept of relative velocity is clarified, indicating it can be used to simplify calculations by avoiding quadratic terms. One participant proposes that after the collision, both objects might travel at the same velocity in the negative direction, leading to a simplified relationship between their velocities. Overall, the conversation highlights the importance of understanding both momentum and energy conservation in analyzing elastic collisions.
Maiia
Two particles of masses m and 3m are moving toward each other along the x-axis
with the same speed v. They undergo a head-on elastic collision and rebound along the x-
axis.
I don't seem to be getting the right answer...I would really appreciate it if someone could help me figure out what I did wrong.
I put the smaller mass as A and the bigger mass as B.
MaVia + MbVib= MaVfa + MbVfb
mv - 3mv= mVfa + 3MVfb
-2mv= mVfa + 3MVfb
then i used relative velocity formula
Vaf-Vbf= -(Vai-Vbi)
Vaf - Vbf= 2v
Vaf= 2v+Vbf
Then I substituted into the equation
-2mv= m(2v+Vbf) + 3MVfb
-2mv= 2mv + 2mVbf + 3MVbf
-4mv= 5mvbf
-4/5v= vbf
Relative velocity formula? What's that? You want to use conservation of momentum (you got that equation right). Now you want to use conservation of energy to get a second equation for Vfa and Vfb. That's what 'elastic' means.
my teacher said we could use relative velocity for head on collisions..
Perhaps you can, but that would be a version of conservation of momentum. You need another relation here. You really have to use conservation of kinetic energy.
I think you mean for elastic collision
velocity of approach = velocity of separation
No. I mean what I said. That's not right.
I think we can get this using energy conservation law. I think from here only we define coefficient of restitution.
I don't know what that is. I think 'elastic'=conserve energy and momentum. Is that the 'relative velocity rule' the poster is talking about? If it is equivalent to energy conservation then it will work. But I just don't know this jargon.
The conservation of linear momentum and energy both leads to a relation
u1 - u2 = v2 - v1
I think this is called relative velocity of approach = relative velocity of separation and can be used with momentum conservation to avoid square terms.
Sorry, the first reply was for student not for you.
Regards
Right, and it does avoid square terms. I'm sorry, I've just never seen this before. Thanks for the enlightenment. And I've got a doctorate in physics. Shows you can always learn new things. Thanks!
Looking at this problem kinda helped me study for my physics final tomorrow as it is on my exam. Anyways getting back on topic. I think that because it is an elastic collision, we can assume that both objects are traveling at the same velocity after the collision in the -x direction.
If we assume that's the case, then I think it would turn out like this instead:
mVi - 3mVi = -(m + 3m)Vf
mVi - 3mVi = -4mVf
-2mVi = -4mVf
Vi = 2Vf or Vf = .5Vi
I'm not sure if this is how it should be conducted, but it seems to work and make sense.
Vaf-Vbf= -(Vai-Vbi)
Vaf - Vbf= 2v
Vaf= 2v+Vbf
I think it should be
Vbf - Vaf = 2v
  • · Replies 17 ·
16K
