Relative Velocity: Car & Rain w/ Respect to Earth
In summary, the velocity of the rain with respect to the car is 15.278 m/s and the velocity of the rain with respect to the Earth can be calculated using the cosine law and the given angle of 70 degrees.
changzv
A car travels due east with a speed of 55.0 km/h. Raindrops are falling at a constant speed vertically with respect to the Earth. The traces of the rain on the side windows of the car make an angle of 70.0° with the vertical. Find the velocity of the rain with respect to the following reference frames.
(a) the car in m/s
(b) the Earth in m/s
I have converted the speed of the car from km/h to m/s which is
v=(55x1000)/3600
=15.278m/s
I have no idea where to start.. Please guide me..
Does the horizontal motion have no relation to the vertical motion therefore velocity of the rain with respect to the car = 15.278m/s?
Thanks in advanced!
Yes, the horizontal motion of the car has no relation to the vertical motion of the rain, so the velocity of the rain with respect to the car is 15.278 m/s. To find the velocity of the rain with respect to the Earth, you will need to use the trigonometric relationship between the angle of 70 degrees and the velocity of the rain. Specifically, you can use the cosine law to calculate the magnitude of the vertical component of the rain's velocity. Let v_r be the velocity of the rain with respect to the Earth. Then you have:v_r^2 = (15.278)^2 + v_y^2 - 2*15.278*v_y*cos(70°)Solving for v_y gives:v_y = (15.278^2 + v_r^2)/(2*15.278*cos(70°))From this, you can calculate the velocity of the rain with respect to the Earth.
Related to Relative Velocity: Car & Rain w/ Respect to Earth
What is relative velocity?
Relative velocity is the measurement of the velocity of an object in relation to another object. It takes into account the motion of both objects and is different from the absolute velocity of an object, which is its velocity in relation to a fixed point.
How is relative velocity calculated?
Relative velocity is calculated by subtracting the velocity of one object from the velocity of another. If the velocities are in the same direction, the relative velocity will be the difference between the two velocities. If the velocities are in opposite directions, the relative velocity will be the sum of the two velocities.
How does relative velocity apply to a car driving in the rain?
In the context of a car driving in the rain, relative velocity refers to the motion of the car in relation to the rain. This means that the car's velocity and the rain's velocity are both taken into account to determine the overall motion of the raindrops hitting the car.
Why is relative velocity important in understanding motion?
Relative velocity is important in understanding motion because it helps us understand the impact of different velocities on an object. It allows us to determine the motion of an object in relation to other objects, which is important in many real-world situations such as driving or flying.
How does relative velocity change when the car's velocity changes?
When the car's velocity changes, the relative velocity between the car and the rain will also change. This means that the raindrops will hit the car at a different angle and with a different force. The overall relative velocity can also change if the velocity of the rain changes.
