MHB Relative Velocity of Aircraft: Mag & Dir Before & After 16:30
An aircraft flies at 200 km/h relative to the air, with wind initially blowing from the east at 100 km/h until 16:30, after which it changes to a south wind at 50 km/h. The aircraft maintains a southwesterly course throughout. Calculations show that before 16:30, the resultant velocity of the aircraft is approximately 257.79 km/h at an angle of about 34.8 degrees west of south after the wind change. The discussion emphasizes the use of vector addition and the Law of Sines and Cosines to determine the aircraft's velocity relative to the wind and ground.
markosheehan
an aircraft flies horizontally at a speed 200 km hr^-1 relative to the air. its position at 15:00 is p. a wind with speed 100 km hr^-1 blows from the east from 15:00 to 16:30 . the wind then changes to a speed of 50 km hr^-1 from the south. the aircraft adjusts its heading so it maintains a south westerly course all the time.
find the magnitude and direction of the of the aircrafts velocity relative to the air both before and after 16:30. also if airport q is 600 km south west of p find the time when the aircraft rrives at q.i could kind of get the answer for before 16:30 but i can not the the right answer of 34.8 degrees west of south for after 16:30. could anyone explain this to me? i am also confused on the wind and the direction in the aircraft should fly at for both the times. i am trying to label Va=aircraft vector , Vw=wind vector and Vaw =vector of the aircraft relative to the wind.
Mathematics news on Phys.org
I would begin by stating the vectors we know...let $\vec{A}$ represent the aircraft, $\vec{W}$ the wind, and $\vec{R}$ the resultant.
So, from 15:00 to 16:30, we have:
$$\vec{A}=200\left\langle \cos(\theta),\sin(\theta) \right\rangle$$
$$\vec{W}=100\left\langle -1,0 \right\rangle$$
And what we want is:
$$\vec{R}=\vec{A}+\vec{W}=|R|\left\langle \cos\left(\frac{5\pi}{4}\right),\sin\left(\frac{5\pi}{4}\right) \right\rangle=-\frac{|R|}{\sqrt{2}}\left\langle 1,1 \right\rangle$$
This gives us the following system:
$$200\cos(\theta)-100=-\frac{|R|}{\sqrt{2}}$$
$$200\sin(\theta)=-\frac{|R|}{\sqrt{2}}$$
This implies:
$$200\cos(\theta)-100=200\sin(\theta)$$
$$2\cos(\theta)-1=2\sin(\theta)$$
Solving this, and using the solution in the 3rd quadrant, we obtain:
$$\theta=2\left(\pi-\arctan\left(\frac{2+\sqrt{7}}{3}\right)\right)\approx245.70481105463543^{\circ}$$
And so:
$$|R|\approx257.793547457352\,\frac{\text{km}}{\text{hr}}$$
Now, can you do the same thing, except with the wind vector that applies after 16:30?
thanks for your reply. i am sorry but i think the answer acceptable on my course is using the cosine and sine rule.
do you know how to do it using that method?
could you show me a diagram of the vectors of the wind,plane and the resultant. i can not visualize the directions.
thanks
That would have been nice to know up front. :p
Yes, I just find vector addition easier.
thanks
The wind vector points to the west and the resultant points to the southwest. So the aircraft's vector will complete the triangle.
Using the Law of Sines, we may write:
$$\frac{\sin(\theta)}{|R|}=\frac{\sin\left(\frac{\pi}{4}\right)}{200}=\frac{1}{200\sqrt{2}}\implies |R|=200\sqrt{2}\sin(\theta)$$
Using the Law of Cosines, we may write:
$$R^2=100^2+200^2-2\cdot100\cdot200\cos(\theta)=100^2\left(5-4\cos(\theta)\right)$$
These two equation imply:
$$8\sin^2(\theta)=5-4\cos(\theta)$$
Using a Pythagorean identity, we may write:
$$8\left(1-\cos^2(\theta)\right)=5-4\cos(\theta)$$
In standard quadratic form, we have:
$$8\cos^2(\theta)-4\cos(\theta)-3=0$$
Using the quadratic formula and discarding the negative root, we obtain:
$$\cos(\theta)=\frac{1+\sqrt{7}}{4}$$
And thus:
$$\theta=\arccos\left(\frac{1+\sqrt{7}}{4}\right)\approx24.29518894536457^{\circ}$$
And so the direction $\alpha$ of the aircraft is:
$$\alpha=270^{\circ}-\theta\approx245.70481105463543^{\circ}$$
And we have the resultant in kph:
$$|R|=200\sqrt{2}\left(\frac{1+\sqrt{7}}{4}\right)=50\sqrt{2}\left(1+\sqrt{7}\right)\approx257.793547457352$$
Now for the new wind direction, we have the wind vector pointing north, and the resultant still points to the southwest. Can you find the new direction and speed of the aircraft relative to the ground (resultant)?
Sorry I should of mentioned it.
Thanks I can do it from here!
Just so you can check you work, I will complete the problem. :D
Using the Law of Sines, we may state:
$$\frac{200}{\sin\left(\frac{3\pi}{4}\right)}=\frac{|R|}{\sin(\theta)}\implies |R|=200\sqrt{2}\sin(\theta)$$
And using the Law of Cosines:
$$R^2=50^2+200^2-2\cdot50\cdot200\cos(\theta)=100^2\left(\frac{17}{4}-2\cos(\theta)\right)$$
These two equations imply:
$$32\cos^2(\theta)-8\cos(\theta)-15=0$$
Discard the negative root, and we have
$$\cos(\theta)=\frac{1+\sqrt{31}}{8}\implies \theta=\arccos\left(\frac{1+\sqrt{31}}{8}\right)\approx34.81793259684111^{\circ}$$
This is west of south. And so the resultant in kph is:
$$|R|\approx161.49485779096793$$
Now, as of 16:30 the aircraft had traveled in km:
$$d_1\approx\frac{3}{2}(257.793547457352)=386.69032118602803$$
This leaves:
$$600-386.69032118602803=213.30967881397197$$
km to go, which will take a time (in hr) of:
$$t\approx\frac{213.30967881397197}{161.49485779096793}\approx1.32084502089888$$
So, the aircraft arrives at the airport at (to the nearest minute) at 17:49. :D
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
