Relative Velocity: Swimming Angle to Reach Shore
Deloris must swim at an angle to counteract the river's current while crossing to safety. The river is 30m wide, and he starts 10m north of his intended landing point. Using vector resolution, the swimmer's angle was calculated to be approximately 73.46 degrees to successfully reach the opposite shore. The discussion highlighted the importance of balancing the swimmer's velocity against the river's current to avoid being swept downstream. Ultimately, the calculations confirmed that with the right angle, Deloris can indeed make it across the river.
mikeh3593
Deloris is being chased through the forest by hungry cannibals. He decides to evade the flesh-eating spider monkeys by crossing a river. He Arrives at the bank of the river 10m[N] of a safe landing on the opposite side. the river is moving at a speed of 3.5 m/s . if he has a maximum swimming speed of 3 m/s, what angle must he swim at in order to make it to the opposite shore?
V(deloris to the shore) = V(Deloris to the water) + V(Water to the Shore)
So far I have used the pythagorean theorem to get the speed 4.61m/s
also to get the distance traveled to the end point to be 22.36m
and the angle of displacement i obtained using tangent which is 63.4 degrees
I think it would help you and us to draw a picture! How wide is the river?
Oh yeah! forgot, sorry, the river is 30m wide.
X | up is [N]
| 10m |
|---------X
| 30m |
sorry I am new i don't know how to make a picture
I think this is what you mean?
[PLAIN]http://img213.imageshack.us/img213/8501/riverz.jpg
Basically you're trying to find the direction he should swim so that he ends up traveling at an angle x from the south direction... (along the blue arrow) I hope my diagram is clear.
The first thing to do would be to work out the angle x.
I have suspicion that he will never make it to the other side :) ? Is this allowed as an answer?
If you choose a nice set of co-ordinates you can find an answer by solving one equation...
how would i go about this? I've been stressing about this question and now i can't even wrap my head around it i have the angle which is 63.4 degrees.
To calculate x, i get:
tan(x)= \frac{30}{10}
x = 71.6 degrees
EDIT: x was a bad choice of letter for this angle... from now on let's just call it a.
Oh my bad the distance was 20m sorry so what where do I go after from getting the angle for a?
I hope you know about resolving vectors to their components!
[PLAIN]http://img593.imageshack.us/img593/5049/river.jpg
If you put a co-ordinate axis onto your problem as i drew in the picture, you can hopefully see: that in order for him to travel in the x direction (towards the safe shore) he better not have any velocity in the y direction.
So we don't know what angle he is going to swim at, but let's call it b. How can he not have any velocity in the y direction? Only if his y direction of velocity is equal and opposite to that of the rivers.
Mathematically you write this:
v_{river} sin(a) = v_{deloris} sin(b)
If you know velocity of the river, you know a and you know velocity of Deloris then you can find b. What do you get?
Ok just do everything I said except use the right distance for the river...
It would be impossible for him to get past if the river was 30m! 20m, he can make it :D
EDIT: Oh... maybe not :P, sure he can't swim any faster? haha
Okay! I have got 73.46 degrees as the final answer, I understand this now! Thank you so much!
