notdroid
- 2
I'm doing some special relativity exercises. I have to find $$x(t), v(t)$$ of a charged particle left at rest in $t=0$ in an external constant uniform electric field $$\vec{E}=E_{0} \hat{i}$$, then with that velocity I should find the Liénard–Wiechert radiated power.
I will show you what I did but I feel that it is wrong.
We should solve the equation of motion given by
\tag{1}\frac{dp^{\mu}}{d\tau} = \frac{q}{c} F^{\mu \nu}u_{\nu}
The four-velocity is given by
u^{\mu} = (u^{0},u^{1},u^{2},u^{3}) = \gamma (c,v^{1},v^{2},v^{3})
where $v^{\alpha}$ are the components of the three-velocity. The four-momentum is
p^{\mu} = mu^{\mu}
This will give us four equtions where two of them will give a constant velocities and the other two are
\tag{2}\frac{d\gamma}{d\tau} = -\frac{qE_{0}}{mc^{2}}\gamma v_{1}
\tag{3}\frac{d\gamma}{d\tau} v_{1} + \gamma \frac{dv_{1}}{d\tau} = \frac{qE_{0}}{m} \gamma
Replacing (2) in (3) gives
\tag{4}\frac{dv_{1}}{d\tau} = -\frac{qE_{0}}{mc^{2}} (v_{1})^{2} + \frac{qE_{0}}{m}
The solution of the ODE (4) gives something like
\tag{5}v_{1}(\tau) = A\tanh{(B\tau)}
This component of the three-velocity is in terms of the proper time tau and the problem ask me to find the velocity in terms of the time t. So my attempt was to solve
\tag{6}\frac{dt}{d\tau} = \gamma (\tau) = \frac{1}{\sqrt{1 - \frac{(v_{1}(\tau))^{2}}{c^{2}}}}
and then replacing this solution for tau in (5). But the solution of (6) is http://www.wolframalpha.com/input/?i=integrate 1/sqrt(1 - a^2*tanh(bx)^2). Which doesn't make any sense to me.
I think that I'm misunderstanding something or missing something that will give me a easier solution to this problem. I thought it because in the Liénard–Wiechert radiated power I sould do
$$dv_{1}/dt$$ which is almost impossible to do it without WolframAlpha.
Thanks for the read.
p^{\mu} = mu^{\mu}
