Relativistic Decay and Separation Between Moving Nuclei A and B
  • Thread starter Thread starter alex_ts
The discussion centers on the application of the relativistic velocity addition formula to analyze the decay and separation of moving nuclei A and B. The calculations involve the transformation of time and distance using Lorentz transformations, specifically addressing the variables Dta and dab. Concerns are raised about the clarity of the mathematical presentation, suggesting the use of LaTeX for better readability. Additionally, there is a critique regarding the inconsistency in using the Lorentz factor γa while applying the relative speed uab in the transformation equations. The overall conclusion is that the solution presented may contain errors that need to be addressed for accuracy.
alex_ts
From the stationary position of the observed O, two nuclei of atoms A and B are launched simultaneously, which move (with respect to O) in the same direction with corresponding constant relativistic velocities ua=ac and ub=bc. c denotes the speed of light and for the constants a and b it is valid that 0<a<b<1. Observer O found that after time t, the two nuclei split simultaneously.
What is the time interval between the decays of the two nuclei with respect to nucleus A? What was the distance (relative to A) between nuclei A and B when A detected the fission of B?
uba=(ub-ua)/(1-uaub/c^2)
Dta=γa(tb-uba*xba/c^2) =>Dta=γa(t-uba*uba*t/c^2)=>Dta=γat(1-uba^2/c^2)
γ=1/(1-(u/c)^2)^1/2
The relative velocity of nucleus B with respect to nucleus A is given by the relativistic velocity addition formula:
γa=1/(1-a^2)^(1/2)
and and we can replace uba with their respective expression.
And the distance at the moment of detection is: dab=uba*Dta and and we can replace uab and Dta with their respective expressions.
Is my solution correct?
Your work is kind of hard to read. It would be easier to follow if you typeset the math using LaTeX.
Anyway, your solution doesn't look correct to me because you're using ##\gamma_a## in the Lorentz transformation but using ##u_{ba}## as the relative speed of the two frames.
Likes SammyS and TSny
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
