I Relativistic Doppler Effect near a Black Hole
Viewing a person rotating near a black hole involves both gravitational redshift and relativistic Doppler effect redshift. If the person moves towards the observer, the Doppler effect causes a blueshift while the gravitational redshift remains. It is possible for the blueshift and gravitational redshift to equalize, allowing the observer to see the light at its original frequency. This cancellation can occur naturally for objects in circular orbits. The discussion emphasizes the interplay between these effects in extreme gravitational environments.
appot89
TL;DR Summary
Relativistic Doppler Effect near a blackhole
Hey everyone, if I were to view a shining person rotating near a black hole at near the speed of light there would be 2 kinds of redshifts: gravitational redshift and relativistic doppler effect redshift. Right?
But, say at some point, the person is traveling towards me, then the doppler effect would result in a blueshift while the gravitational redshift would remain. Is it possible that if the doppler effect blueshift and the gravitational redshift were equal, would I view the light shining at its original frequency?
Astronomy news on Phys.org
Yes.
You can always adjust your speed relative to a nearby hovering observer so that your kinematic blueshift cancels the gravitational redshift, yes. It'll happen naturally at some point for an object in a circular orbit (and probably any other), if my algebra is correct.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
