Relativistic Effect on Attraction between Moving Masses?
In summary, there is a similar effect to magnetism when masses move relative to each other, called "gravitomagnetism." This idea is discussed in most relativity textbooks. When masses are moving at relativistic speeds, the acceleration appears to be slower due to time dilation. The shape of space also affects the acceleration of a test particle. The concept of "gravitational force" is tricky to define, but can be qualitatively understood by imagining a coulomb-like attraction between sources of energy and a magnetic-like repulsion when masses are parallel. However, this analogy is limited and a deeper understanding is needed to fully explain the effects of masses moving relative to each other.
ObjectivelyRational
150
Magnetism has be explained as a relativistic effect of moving charges. This was something we were shown in undergrad.
Is there a similar effect when masses move relative to each other?
1. Is there any difference between the gravitational force between a single massive particle and a very long "line" of mass at rest wrt the particle versus when the "line" of mass is traveling at relativistic speeds (in the same direction as the line) in relation to the particle?
2. Is there any difference between the gravitational force between two parallel lines of mass at rest wrt each other versus the lines of mass traveling at relativistic speeds (along the same directions as the lines) in relation to each other?
Why?
Why?
In General Relativity, there are similar effects when masses move relative to each other, although they are a bit more complicated than for electromagnetism.
In many simple cases (provided that fields are not extremely strong), you can simply use Special Relativity. If you transform the system to a frame where the source masses are at rest and calculate the acceleration in that frame, you can then use a Lorentz transformation on the acceleration to find the acceleration in the original frame. This applies in particular to your case (2). You will find that the acceleration gets time dilated more and more and hence appears to be slower when the lines of mass are moving faster.
When a test particle is moving at relativistic speed relative to a gravitational source, the path differs somewhat from Newtonian theory mainly because of curvature with respect to space. However, if one calculates the acceleration taking that into account, it can then be transformed using Special Relativity to a new frame.
I must admit I don't recall off hand what effect a very long line of mass has on the shape of space, so I don't know exactly what acceleration a relativistic test particle would experience in that case, but if you can calculate the acceleration when the line is at rest but the particle is relativistic and then transform it to bring the particle to rest then that would give the answer to your case (1).
Yes. It is called "gravitomagnetism" and is discussed in most major relativity textbooks.
Thank you!
Yes, there is an analogous effect, as some other posters have already mentioned. See https://en.wikipedia.org/wiki/Gravitoelectromagnetism for some of the technical details
Why?
"Gravitational force" turns out to be trickier to rigorously define than one might expect. The following factoids might help illustrate some of the principles while sidestepping the issues arising from discussing "gravitational force".
Two parallel light beams won't attract. Left to themselves, they'll remain parallel and at a constant distance from each other as they propagate.
Two anti-parallel light beams will attract. Left to themselves this attraction means that if they start out anti-parallel, they won't remain so. In an extreme example, one can imagine two anti-parallel light beams orbiting around a common center with no other forces or gravitational influences, though this situation turns out to be unstable.
A motionless test particle will be attracted to a nearby passing laser pulse.
A light beam passing by a large mass will be deflected by twice the amount that one would expect from a naive calculation.
These factoids can be qualitatively integrated into a coherent picture by imagining that the energy in the parallel light beams causes an attraction analogous to the electrostatic coulomb force due to charge. The analogy here is between the electromagnetic forces between charges, and the gravitational attraction between sources of energy. This "coulomb" attraction is counterbalanced a a "magnetic-like" gravitational repulsion when the light beams are parallel. When they are anti-parallel, the "coulomb-like and "magnetic-like" forces point in the same direction rather than opposite directions.
The factor of two deflection of a light beam by a test mass illustrates a need for caution with Newtonian analogies. You'll get a qualitative understanding of what happens by such analogies, but to really get accurate answers and to understand where this factor of 2 comes from will require deeper study, and I won't attempt to describe "why" in this short post. If you pursue the GEM (GravitoElectroMagnetism) analogy (see the wiki reference), which compares weak-field gravity to electromagnetism, you'll see this factor of 2 in the GEM equations.
For an old and rather confusingly worded reference on the behavior of parallel and anti-parallel light beams, see for instance http://journals.aps.org/pr/abstract/10.1103/PhysRev.37.602
Related to Relativistic Effect on Attraction between Moving Masses?
What is the relativistic effect on attraction between moving masses?
The relativistic effect on attraction between moving masses refers to the phenomenon where the gravitational attraction between two masses changes due to their relative velocities. This effect is described by Einstein's theory of general relativity.
How does the relativistic effect affect the force of attraction between moving masses?
The relativistic effect can either increase or decrease the force of attraction between moving masses, depending on their velocities and the direction of their motion. This is because the mass and energy of an object increase with its velocity, which in turn affects the strength of its gravitational field.
What is the equation for calculating the relativistic effect on attraction between moving masses?
The equation for calculating the relativistic effect on attraction between moving masses is given by F = Gm1m2 / (r^2 * sqrt(1-v^2/c^2)), where F is the force of attraction, G is the gravitational constant, m1 and m2 are the masses of the objects, r is the distance between them, v is the relative velocity, and c is the speed of light.
How does the relativistic effect on attraction between moving masses differ from Newton's law of universal gravitation?
The relativistic effect on attraction between moving masses takes into account the effects of special relativity, such as time dilation and length contraction, which are not considered in Newton's law of universal gravitation. Additionally, the relativistic effect considers the mass-energy equivalence, whereas Newton's law only considers the mass of an object.
What are some real-world examples of the relativistic effect on attraction between moving masses?
One example is the relativistic motion of planets around the Sun. The relativistic effect causes a slight increase in the gravitational force between the planets and the Sun, resulting in a slightly shorter orbital period. Another example is the gravitational attraction between two high-speed spacecraft, which would be stronger than if they were stationary due to their increased masses.
