Relativistic force and electromagnetic tensor follow up
In summary: D?In summary, the following is true:1. There is a chicken-egg problem with the derivation of the 4-force in relativity.2. The electromagnetic Lagrangian and/or Hamiltonian is a better and more fundamental description of the electromagnetic field than one in terms of forces.3. The 4-force is equal to the 4-velocity divided by γ, and the 4D version of Newton's second law divided by γ.
Wox
70
A while back (thread) you guys helped me understand why [itex]\tilde{F}=m\frac{d\gamma\tilde{v}}{dt}[/itex] (3-vectors) as it follows from [itex]\bar{F}=q\Psi\bar{v}[/itex] (4-vectors) and [itex]\tilde{F}=q(\tilde{E}+\tilde{v}\times \tilde{B})[/itex] (3-vectors). However, I had the impression that one also uses [itex]\tilde{F}=m\frac{d\gamma\tilde{v}}{dt}[/itex] in relativistic mechanics, making abstracting of the nature of the force and therefore not necessarily being electromagnetic as in its derivation. Is that true?
Secondly, there appears to be a chicken-egg problem here. Where does [itex]\bar{F}=q\Psi\bar{v}[/itex] come from? I assume it follows from the classical Lorentz force, but what are the extra's? [itex]\tilde{F}=m\frac{d\gamma\tilde{v}}{dt}[/itex] can't be part of it because then we do have a chicken-egg problem. I've been trying to find some comprehensive reference that builds this up from classical electrodynamics and the properties of Minkowski space, but without success.
I am not sure what [tex\Psi[/tex] stands for.
The concept of 'force' is unnecessary in relativity or in QM, and can lead to confusion sometimes. Even with Newton's F=ma there is a chicken-egg problem--Does it define force or mass?
Sorry, [itex]\Psi[/itex] is the electromagnetic tensor.
Basically F=m (d/dt) (gamma * acceleration) is not correct. So you'll have a hard time justifying it. See the discussion in wikki about the rather outdated "transverse" and "longitudinal" masses.
http://en.wikipedia.org/w/index.php...id=491515263#Transverse_and_longitudinal_mass
Specifically, if an object is moving in the x direction with velocity v:
f_x = m gamma^3 a_x
f_y = m gamma a_y
f_z = m gamma a_z
Note that the power of gamma is 3 in the direction of motion, and unity transverse to the direction of motion.
I'd also argue that the electromagnetic Lagrangian and/or Hamiltonian is a better and more fundamental description of the electromagnetic field than one in terms of forces. If you're not familiar with Lagrangians or Hamiltonians yet I'd suggest reading about them, a fairly standard reference is Goldstein's "Classical Mechanics".
Check out the first few pages of Chapter 3 in MTW. The quantity [itex]\bar{F}=q\Psi\bar{v}[/itex] is equal to the 4-force divided by γ, and [itex]\tilde{F}=m\frac{d\gamma\tilde{v}}{dt}[/itex] is the 4D version of Newton's second law divided by γ. As reckoned from any secific inertial frame of reference, the γ's cancel. However, you should understand that, prior to the cancelation of the γ's, the equations were originally expressed in terms of the 4 force, the 4 velocity, and the 4 acceleration.
Chet
Ok, now I'm confused.
[itex]\bar{F}[/itex]: four force
[itex]\bar{v}[/itex]: four velocity
[itex]\bar{p}[/itex]: four momentum
[itex]\tau[/itex]: proper time
[itex]\Psi[/itex]: electromagnetic tensor
[itex]\tilde{F}[/itex]: three force
[itex]\tilde{v}[/itex]: three velocity
[itex]\tilde{E}[/itex]: electric field
[itex]\tilde{B}[/itex]: magnetic field
[itex]q[/itex]: charge
[itex]\bar{F}=\frac{d\bar{p}}{d\tau}=q\Psi\bar{v}[/itex]
[itex]\Leftrightarrow \gamma \frac{d\bar{p}}{dt}=\gamma\Psi(c,\tilde{v})[/itex]
[itex]\Leftrightarrow \frac{d\bar{p}}{dt}=\Psi(c,\tilde{v})[/itex]
[itex]\Leftrightarrow (mc\frac{d\gamma}{dt},m\frac{d\gamma\tilde{v}}{dt})=\Psi(c,\tilde{v})[/itex]
(take only the spatial part)
[itex]\Leftrightarrow m\frac{d\gamma\tilde{v}}{dt}=q(\tilde{E}+\tilde{v}\times\tilde{B})[/itex]
[itex]\Leftrightarrow m\frac{d\gamma\tilde{v}}{dt}=\tilde{F}[/itex]
the relativistic version of Newton's second law of motion in 3D. Now the question is, what follows from what? From classical electrodynamics we have [itex]\tilde{F}=q(\tilde{E}+\tilde{v}\times\tilde{B})[/itex]. So how do we end up at [itex]\bar{F}=q\Psi\bar{v}[/itex]? Or better, where is our starting point: on the top or on the bottom of the above scheme?
Chet
In equation 3.2a they use [itex]\frac{dp}{dt}=e(E+v\times B)[/itex] where [itex]p[/itex] the four momentum. How is that possible, the left hand side is in 4D while the right hand side is in 3D.
On page 73, note carefully the difference in font for p for 3-dimensional notation and for 4-dimensional notation.
If you take the time derivative of [tex]m\gamma{\bf a}[/tex],
you get [tex]d/dt(m\gamma{\bf a})=m\gamma^3[{\bf a+v\times(v\times a})[/tex],
which is just what you wrote.
If you just substitute for the EM tensor and the 4-velocity, you get the Lorentz force for the vector part.
This is all explained very effectively and in detail in the first few pages of Chapter 3 in MTW. Study it carefully. You'll get the idea.
Chet
FAQ: Relativistic force and electromagnetic tensor follow up
What is the relationship between relativistic force and electromagnetic tensor?
The electromagnetic tensor is a mathematical object that describes the electromagnetic field in terms of its electric and magnetic components. Relativistic force, on the other hand, refers to the force experienced by a charged particle when it is moving at relativistic speeds. The two are related through the Lorentz force law, which states that the force on a charged particle is equal to its charge multiplied by the sum of the electric and magnetic fields at its location.
How does the electromagnetic tensor follow up to Maxwell's equations?
The electromagnetic tensor is a mathematical construct that was developed to simplify and extend Maxwell's equations, which describe the behavior of electric and magnetic fields. In tensor form, Maxwell's equations can be expressed in a more elegant and compact way, making it easier to manipulate and solve complex problems.
Can you explain the concept of gauge invariance in relation to the electromagnetic tensor?
Gauge invariance is a fundamental property of Maxwell's equations and the electromagnetic tensor. It means that the equations remain unchanged when certain transformations are applied to the electric and magnetic fields. This is important because it allows us to choose a particular gauge, or mathematical representation, that is most convenient for solving a particular problem without changing the physical predictions of the equations.
How does the electromagnetic tensor account for the speed of light in vacuum?
The electromagnetic tensor plays a crucial role in the special theory of relativity, which states that the speed of light in vacuum is constant for all observers. The tensor includes terms that account for the speed of light, and its mathematical form is such that it remains invariant under Lorentz transformations, the mathematical framework that describes how measurements change between different reference frames moving at constant velocities.
What are some practical applications of the electromagnetic tensor?
The electromagnetic tensor has a wide range of practical applications, from understanding the behavior of electric and magnetic fields to developing new technologies. Some examples include the design of particle accelerators, the development of electromagnetic propulsion systems for spacecraft, and the study of quantum electrodynamics, the theory that describes the interactions between light and matter at the subatomic level.
