- 10,318
- 1,489
I wanted to re-do Egan's results for relativistic hoops with a different model, one with a relativistic hoop with a constant circumference. The idea is that by having the circumference not change as we spin up the hoop, we shouldn't be storing energy by "stretching" the material of the hoop. Putting the material of the hoop under tension without changing it's length shouldn't do any work.
Of course, keeping the circumference of the hoop constant means its radius must shrink.
Informally, this would be an approximation of a 'rigid' hoop, though of course one can't change the state of rotation of a rigid body in special relativity. For a thin enough, hoop, though, we should be able to approximate a rigidity.
We'll start with a standard cylindrical metric in 2 spatial dimensions and geometric units:
$$-dt^2 + dr^2 + r^2\,d\phi^2$$
Following Egan's lead from <<link>>, we'll introduce Langevin vectors u and w. See also <<wiki link>>
$$u = \frac{1}{\sqrt{1-r^2\omega^2}} \left( \partial_t + \omega \, \partial_\phi \right) \quad w = \frac{1}{\sqrt{1-r^2\omega^2}} \left( \omega \, r\,\partial_t + \frac{1}{r} \partial_\phi \right)$$
Then we can write the stress energy tensor in a coordinate basis as:
$$T = \rho \, u \otimes u + P \, w \otimes w$$
where ##\rho## is the density of the hoop and P is a negative number equal to the magnitude of the tension in the hoop, as seen by the Langevin observer. Both ##\rho## and P are only functions of r, they do not depend on t or ##\phi##.
By setting ##\nabla_a T^{ab}=0##, we can solve for the pressure, ##P = -\rho \, r^2\,\omega^2##
Substituting for P as a function of ##\rho## yields the following stress energy tensor in a coordinate basis
$$T^{ab} = \begin{bmatrix} (1 + r^2\omega^2) \rho & 0 & \rho \omega \\ 0 & 0 & 0 \\ \rho \omega & 0 & 0 \end{bmatrix}$$
Introducing an orthonormal basis of one-forms for the cylindrical metric, i.e. dt, dr, and ##r\,d\phi##, we can write the stress-energy tensor in an orthonormal basis as:
$$T^{\hat{a}\hat{b}} = \begin{bmatrix} (1 + r^2\omega^2) \rho & 0 & -\rho \,r \, \omega \\ 0 & 0 & 0 \\ -\rho \,r \,\omega & 0 & 0 \end{bmatrix}$$
Next, we need to solve for how the radius of the hoop decreases as we spin it up while keeping it's circumference constant.
Keeping the circumference of the hoop constant demands that
$$r_0 = \frac{r_i}{\sqrt{1-r_i^2\omega^2}}$$
where ##r_0## is the radius of the hoop at ##\omega=0## and ##r_i## is the shrunk radius of the spun-up hoop.
Solving for ##r_i##, we find.
$$r_i (\omega) = \frac{r_0}{\sqrt{1+r_0^2\omega^2}}$$
By integrating ##T^{\hat{0}\hat{0}}## over the 'volume' of the hoop, ##2 \pi r_i## we get the total energy E
$$E = 2\,\pi\,r_i \,\rho \sqrt{1 + r_i^2\,\omega^2} = 2\,\pi\,r_0 \,\rho \frac{1 + 2\,r_0^2\,\omega^2}{(1+r_0^2\,\omega^2)^\frac{3}{2}}$$
E seems sensible, it gives the expected results for energy in the limit where ##\omega## is small. The value for E when ##\omega=0## is just ##2\,\pi\,r_0\,\rho##.
Integrating the angular momentum density r ##\times \rho \, r\,\omega## over the volume ##2 \pi r_i## appears to be more problematical, because the angular momentum reaches a peak, then starts to decrease.
$$L = \frac{2 \, \pi \, r_0^3 \, \omega \, \rho } { \left( 1 + r_0^2\,\omega^2 \right) ^ \frac{3}{2}}$$
It's unclear if I've made some error, or how to interpret this if no error was made.
