Relativistic Kinetic Energy as a solution to a DE
In summary: Has anyone ever seen KE derived this way?The only non-classical assumption is that mass = Energy/c^2 (I know, that's a big one) and that it accumulates as mass as the object is accelerated. (sorry for the plain text formatting, I need to learn how to do it right, I may reply with my first try)
AVentura
106
Has anyone ever seen KE derived this way? The only non-classical assumption is that mass = Energy/c^2 (I know, that's a big one) and that it accumulates as mass as the object is accelerated. (sorry for the plain text formatting, I need to learn how to do it right, I may reply with my first try)
KE(v)=∫ dp/dt dx = ∫ v dp
p = mv , m = (mo + KE(v)/c^2)
so: p = mo*v + KE(v)*v/c^2
and dp = mo*dv + dKE(v)*v/c^2 + KE(v)/c^2*dv
KE(v)=∫ [v*(mo*dv + dKE(v)*v/c^2 + KE(v)/c^2*dv)]
or KE'(v) = v*mo + KE'(v)*v^2/c^2 + KE(v)*v/c^2
The solution to this DE is k/√(1-v^2/c^2)-mo*c^2
If KE(0)=0 then k=mo*c^2
and KE= mo*c^2(gamma-1), which is correct.
I find this interesting because it does not involve using p=m*dx/dτ as momentum, and instead uses p=mv, with the mass growing. I never understood using a moving object's proper time to find momentum. The observer is the only one claiming motion after all.
No, it isn't. You are also assuming this:
That equation is not implied by the assumption that mass increases as the object is accelerated. It is an additional assumption--and one that is logically equivalent to the "conclusion" you are saying you have "derived". You haven't actually derived anything; you've just shown the implications of assuming that KE(v) is defined as the quoted equation above defines it.
Once you have relationship between energy and mass, is it not classical to say, "You have a mass, and I give you additional mass, therefore you have the sum of those masses"?
If by "mass" you mean "energy", then if you stick to a single inertial frame, yes, energy is additive. I'm not sure what that is supposed to show.
As PeterDonis already mentioned, this is an additional assumption, but you do not need it. Your original assumption implies
[itex]dE = v \cdot dp = m \cdot v \cdot dv + v^2 \cdot dm: = dm \cdot c^2[/itex]
This results in the differential equation
[itex]\frac{{dm}}{m} = \frac{{v \cdot dv}}{{c^2 - v^2 }}[/itex]
and integration gives
[itex]m = \frac{{m_0 }}{{\sqrt {1 - \frac{{v^2 }}{{c^2 }}} }}[/itex]
This equation already shows that your assumption is actually not classic. As it has real solutions for |v|<|c| only, c is a speed that cannot be reached or exceeded by objects with rest mass. Such a speed limit is not consistence with Galilean transformation but with Lorentz transformation.
To get the kinetic energy you just need to include this "mass" into your assumption:
[itex]E_{kin} = E\left( v \right) - E\left( 0 \right) = m_0 \cdot c^2 \cdot \left( {\frac{1}{{\sqrt {1 - \frac{{v^2 }}{{c^2 }}} }} - 1} \right)[/itex]
^ I like that! I realize that there are lots of ways to show p=gamma*m*v, or KE=mc^2(gamma-1). Just the knowledge (or assumption) that all observers measure the speed of light as c is enough. Thank you for the replies.
I just don't see why p=mdx/dτ is the right way to convey the relativistic form of p, as advanced texts do. It seems perfectly fine to me to conceptualize the phenomenon as an increase of mass.
The reason this formulation is often used is that it is independent of coordinates, i.e., independent of a choice of inertial frame. That often makes the analysis easier; plus, it generalizes much more easily to curved spacetime. In flat spacetime, given a particular choice of inertial frame, however, your formulation gives the same answers, so it is a valid way of looking at it.
The reason this is often discouraged is that for many people it invites confusion. For example, a common question we get here on PF is whether an object becomes a black hole if it moves fast enough, since it mass keeps increasing. The formulation using proper time ##\tau## makes it much easier for many people to avoid such confusions.
There are a couple of good reasons:
In spacetime, coordinate spatial velocity is not a vector at all. If you ask for a 4-vector that is analogous to velocity you get 4-velocity, which inherently includes scaling of components by gamma.If you then go to an acceleration, you get 4-acceleration as the simplest possible vector.
Then, if you multiply 4-velocity by mass, you get momentum as an 4-vector (or covector, for use in a Lagrangian). You immediately recover the desirable feature that mass only changes due to absorption or emission. All the other 'features' of relativistic mass are 'bugs' from (falsely) pretending spatial velocity is a vector in SR.
Is it possible that these are all just conveniences that become available once we start including the work we do accelerating a mass, into the mass as we push? And that additional mass is Work/c^2?
Or I should say, nature requires we account for that work into mass, and then everything else follows?
Where is the 'work' in 4-velocity?
Consider also that the most useful definition of total energy in SR (c=1) is:
E2 = m2 + p2
Here, m is invariant. Besides m, it is momentum that contributes. Momentum grows non-linearly with velocity because of the invariant limiting speed.
I just know that to accelerate an object something must apply a force over a distance to that object. The work done in the process adds an amount of mass (or apparent mass) equal to that work/c^2.
No, work is energy. The idea that energy = mass is due the false simplification of:
E2 = m2c4 + p2c2
into:
E = mc2
The KE in an object (rotational, oscillatory, heat) contribute to the mass of the object, do they not?
Perform work on a spring, you increase its mass (as in rest mass) too.
That's because p doesn't change for the body as a whole. The complete equation explains so much more than the incomplete equation.
Focus again on a point someone made earlier: why doesn't accelerating an object eventually lead to a BH? Because the invariant quantity mass (and the corresponding invariant - total curvature measured from infinity) does not change at all. Meanwhile, adding energy to a body from 'all sides' so its p remains constant, does eventually lead to a BH.
I get that. But i still wonder if increasing your momentum increases your overall mass (I know I'm not supposed to say that) and it's this that makes a velocity of c impossible for objects with non zero rest mass. Drstupid's use of the infinitesimal dm (however discouraged) is quite elegant to me.
This all depends on mv, with v spatial as the definition of momentum. I (and many others) claim this is not correct for SR. Momentum and velocity are vector quantities in Newtonian mechanics, and one expects them to be vector quantities in SR. However, spatial coordinate velocity is not a vector quantity in Minkowski spacetime. As soon as you replace it with the closest analog that is a vector, you see that the 'speed limit' is a feature of the geometry not of 'growing mass'.
To add to my prior observation, consider the algebra of velocities. Velocities add as:
(u+v)/(1+ uv/c2)
There is no mass, work, etc. here, just the algebraic structure of SR. This algebra is even true for u or v = c. Again, 'growing mass' has nothing to do with the invariant speed limit.
I can see that being correct.
But isn't that just why a traveler's claimed speed added to a frame I see moving does not exceed c to me? I think I can still claim the reason why he can't beat c is because he is getting so heavy during acceleration. And claim he is simply wrong about his speed due to his time dilation (and length contraction).
And he can claim the same about you. Then you get into all the foolish false paradoxes of how can both ratios (his mass to mine, mine to his) approach infinity. I am not claiming there is no way to reconcile all this in some consistent framework involving relativistic mass; what I am suggesting is that all of this becomes irrelevant, even inexpressible, once you accept that nature is telling you the algebra and geometry of the universe are not what you thought from Newton.
Note that there are formal derivations showing that being unable to detect absolute (non-accelerated) motion, combined with isotropy and homogeneity, lead uniquely to either Minkowski algebra/geomertry or Euclidean 3-space X time fiber bundle. Nothing about mass, work or energy are needed. Then, the fact that we observe the algebra of SR velocity addition settles which applies to our universe, without a single question about mass, force, energy, or even light.
Thanks for information. I'm going to take a look at minkowski. I've always liked the Fitzgerald prospective (relativistic effects are real, be it length or weight), and it helped me predict that the CERN neutrino speed experiment was an error (they would have gotten a different result later in the day). I realize that there may be more fundamental reasons at play, that I simply don't grasp yet. But my viewpoint also helped me independently discover the bell spaceship paradox as well. I won't give up this view easily, but I realize I must try for the sake of my own knowledge. Thanks again, everyone.
You're welcome, and keep thinking and asking questions.
AVentura said:
I get that. But i still wonder if increasing your momentum increases your overall mass (I know I'm not supposed to say that) and it's this that makes a velocity of c impossible for objects with non zero rest mass. [..].
It's an intuitive way to describe it, and as long as your correctly use the definitions with that description then it's not wrong. Just make sure that other people who use different definitions understand what you mean :oldwink: . (on purpose I here use an "old school"wink!)
That depends on the definition of mass. If you use mass as defined by Newton it is possible (as demonstrated above). If you use mass as usually used in physics today, it is impossible, because rest mass is by definition frame independent. It is a matter of taste which concept of mass you prefer. But you must be aware that most physicists will read "mass" as invariant mass only and many of them will not understand you, even if you clearly communicate which concept of mass you are referring to. This is something like the first Commandment of physics: "I AM THE MASS, THE REST MASS. YOU SHALL NOT HAVE OTHER MASSES BEFORE ME!"
However, as relativistic mass and 3-vectors work quite well in special relativity it doesn't make much sense to use them in general relativity. The latter requires more powerful mathematical tools and it is a good idea to use them from the beginning.
There wouldn't be much left if we start to ban everything that might invite confusions.
That doesn't result from the wrong concept of mass but from the wrong theory of gravitation. Under relativistic conditions Newton's law of gravitation doesn't work with rest mass as well.
Related to Relativistic Kinetic Energy as a solution to a DE
1. What is relativistic kinetic energy?
Relativistic kinetic energy is the energy an object has due to its motion at speeds close to the speed of light. It takes into account the effects of special relativity, such as time dilation and length contraction, on an object's kinetic energy.
2. How is relativistic kinetic energy related to a differential equation?
Relativistic kinetic energy can be derived from the relativistic momentum equation, which is a differential equation that describes the relationship between an object's momentum and its velocity. By solving this equation, we can obtain the expression for relativistic kinetic energy.
3. Why is relativistic kinetic energy important?
Relativistic kinetic energy is important because it allows us to accurately calculate the energy of objects moving at high speeds, which is necessary in many fields of physics, such as particle physics and astrophysics. It also helps us understand the effects of special relativity on an object's energy.
4. How is relativistic kinetic energy different from classical kinetic energy?
Relativistic kinetic energy differs from classical kinetic energy in that it takes into account the effects of special relativity, whereas classical kinetic energy only applies to objects moving at speeds much slower than the speed of light. Relativistic kinetic energy also has a different mathematical expression compared to classical kinetic energy.
5. Can relativistic kinetic energy be applied to all objects?
Relativistic kinetic energy can be applied to all objects, as long as they are moving at speeds close to the speed of light. However, the effects of special relativity become negligible at slower speeds, so classical kinetic energy is a more accurate approximation in those cases.
