Relativistic Kinetic Energy: Does Mass Change?
In summary, according to Special Relativity, the mass of an object must increase as its speed approaches the speed of light. This is done by multiplying the mass by a constant called γ. The correct relativistic expression for the kinetic energy is found by taking the derivative of the mass with respect to time.
Weam Abou Hamdan
25
Hello,
According to Special Relativity, the mass of an object must increase as its speed approaches the speed of light.
m=m0γ
In the formula that allows us to calculate the kinetic energy of a body, KE=0.5mv2, should we take into consideration such increase in mass?
Weam Abou Hamdan
Wednesday, August 22, 2018
Weam Abou Hamdan said:
Hello,
m=m0γ
That ##mv^2/2## formula for the kinetic energy is a classical approximation that only works at speeds that are small compared the speed of light. The correct relativistic expression for the kinetic energy is ##(\gamma-1)m_0c^2## where ##\gamma=1/\sqrt{1-\frac{v^2}{c^2}}## and ##m_0## is the mass of the object when it is at rest. (It would be a good exercise to confirm that this expression approaches ##mv^2/2## when ##v## is small compared with ##c## - expanding ##\gamma## in a power series in ##v/c## will do the trick).
Although you'll hear that bit about the mass of an object increasing a lot, this idea has been largely abandoned in recent decades - there are better ways of describing what happens. This comes up so often that we have an Insights article: https://www.physicsforums.com/insights/what-is-relativistic-mass-and-why-it-is-not-used-much/
Even as early as Einstein the concept of relativistic mass has been recommended against. Here is a good paper on the topic:
https://arxiv.org/abs/physics/0504110
Likes PAllen, Demystifier and Sorcerer
Hello,
m=m0γ
Weam Abou Hamdan
Please stop thinking about relativistic mass. Instead, find out what proper time is, and use the quantity t/γ as time and do the normal kinematic derivation of kinetic energy. The γ will end up giving you the relativistic kinetic energy formula.
Using t/γ as time:
Divide x by t/γ
Miltiply by m to get relativistic momentum
Take the derivative with respect to t to get force
Integrate over distance (changing the variable to v) to get relativistic kinetic energy.
Basically the same thing you’d do in non-relativistic physics but starting with t/γ instead of t.This old post by a site mentor goes through it more concisely:
https://www.physicsforums.com/threads/derivation-of-relativistic-energy.63380/#post-458653
Related to Relativistic Kinetic Energy: Does Mass Change?
1. How does mass change in relation to relativistic kinetic energy?
According to Einstein's theory of relativity, mass does not change in relation to relativistic kinetic energy. However, the perceived mass of an object may increase due to its increased energy.
2. What is the formula for calculating relativistic kinetic energy?
The formula for calculating relativistic kinetic energy is E = (γ - 1) * mc^2, where E is energy, γ is the Lorentz factor, m is the mass of the object, and c is the speed of light.
3. Does relativistic kinetic energy only apply to objects traveling at the speed of light?
No, relativistic kinetic energy applies to all objects traveling at high speeds, not just the speed of light. However, as an object approaches the speed of light, its relativistic kinetic energy increases significantly.
4. How does relativistic kinetic energy differ from classical kinetic energy?
Relativistic kinetic energy takes into account the effects of special relativity, such as time dilation and length contraction, while classical kinetic energy does not. As an object approaches the speed of light, the difference between the two energy values becomes more significant.
5. Can relativistic kinetic energy be negative?
Yes, relativistic kinetic energy can be negative if the object's speed is less than the speed of light. This occurs when the object has lost energy, such as through a collision or friction.
