Relativistic Mass of an Orbiting Billiard Ball
In summary, the conversation discussed the hypothetical scenario of only one billiard ball existing in the universe. The focus was on the inertial mass of the eight ball, and how it would be affected by its speed and location in different reference frames. The question of whether the center of mass or the number 8 on the surface of the ball should be considered at rest was also raised, along with the concept of external forces and their impact on the ball's motion. Overall, the discussion highlighted the importance of using standard terminology and specifying the frame of reference in order to accurately predict the behavior of objects in physics.
  • #36
Tom Mattson said:
What are you going to change the number of vibrations with? Experimentally, the only way to create new electrons is to create an electron-positrion pair. Naturally, that process conserves charge as the produced pair has zero net charge.
Could an external magnetic field change it?
Regards,
Guru
  • #37
Tom: What are you going to change the number of vibrations with?
PG: Could an external magnetic field change it?
Not according to any observational evidence.
  • #38
Physicsguru said:
I am curious, exactly why do you tell him that the momentum p of the object will not be related to the energy E by p/v= E/c2?
Its easily shown by a simple example which I've provided somewhere here.
You have a steel bar at rest in some inertial reference frame S. The steel bar is at absolute zero degrees kelvin, so no radiation is being emitted. Furthermore nothing inside is moving relative to anything else inside. Thus, the system is certainly closed, nothing is entering it or exiting it.
Such a body will be Lorentz contracted when you change frames or the body's speed is increased.
Now, an external agent exerts two equal forces in opposite directions which "stretch the iron bar."
Such an operation will change the energy of the system.
At any rate, ok so someone stretches this bar.
You've added a new complication to the problem, i.e. stretching. That is different than Lorentz contraction which is at the heart of the derivation.
As for the system energy that has increased. Energy was put into the system. Is this what you mean?
No.
pervect said:
Ah, I see. Your definition of the term relativisitc mass appears to be in conflict with the definition used in the sci.physics.faq
The maintainer of that page doesn't want to make changes to it even when the change is a correction. When I did make recommendation that is what he told me. But I'm not referring to online sources (since I don't have any faith in them). I'm referring to the physice/relativity literature.
You might want to write to the maintainer of the sci.physics.faq and give them both your defintion of the term "relativistic mass" along with appropriate references to the literature for why your definition is right.
Why would I want to do that? I rarely seen a relativity text which uses relativistic mass which has the definition wrong. I always seem them get it right. As I stated above the person who maintains that page doesn't want to change it. The change I recommended was not signifigant enough for him to change it. He said other things too so I didn't bother anymore. I know I'm right so there is no reason for me to make more suggestions on this matter.
I don't personally use or like the term "relativistic mass", and since the textbooks I own (Wald & MTW)
That is incorrect. MTW does use relativistic mass in certain places. I think Wald does too in at least one place. But I know of at least two significant places where MTW uses rel-mass. Peacock uses it too.
Since you're the biggest fan I know of the term "relativistic mass", I'll at least accept that p/v is what you mean when you say "relativistic mass".
"Fan" is an not an accurate description. I post on the matter only when people make an error on this subject.
OK, I'm definitely not getting what you are saying. You are claiming that the sum of the momenta of a group of particles in a non-closed system isn't well defined, but you are claiming that the relativistic mass, the ratio of this undefined momentum to a velocity v, is well definied?
Sorry. I made an error there. Invariant mass (magnitude of 4-momentum) is well defined for a closed system but not well-defined for a non-closed system.
If all the individual momenta are definied, why isn't the sum defined?
I didn't say that the sum is not defined. I said it is not "well" defined.
I would say the sum of momenta of a group of particles acted on by external forces is a "function of time", not "undefined".
When you add the momenta of such particles for a sysem then to do this one normally adds the space and time components at a given time in the observers frame of reference. But "at the same time" is not a Lorentz invariant concept. This is too hard to explain here. However I did make an entire page for it. See
http://www.geocities.com/physics_world/sr/invariant_mass.htm
See the section labled "Invariant Mass of a System of Particles - Non-Closed System "
I recommend that you give what I said a try. I.e. take a box in S' and let the edges coincide with the x'y'z' axes. Let there be two forces acting on the box. One on the +x face acting in the -x direction. Let the second force act on the -x face acting in the +x direction. Find the total energy of the box. Find the total momentum of the box. Compare them and you'll see that p/v = E/c^2 does not hold in this case.
Pete
  • #39
I've never seen the actual phrase "relativistic mass" used in MTW. If you can point out a section in MTW that favors your defintion of relativistic mass over the one in the FAQ I'd be very interested to see it.
If you say so.
OK, that webpage was a lot clearer (due to the extra length and the diagrams and examples), but it boils down to what I thought you were saying earlier.
The way I view the situation is slightly different from yours. I regard the momentum and energy of a distributed non-closed system as being a well-defined function of time once the system is exactly defined. Part of the definition of the "system" is a defintion of simultaneity.
Two systems with different concepts of simultaneity are not the same, physical system - the events that make up the system are different.
I also think I disagree with your concluding statement
"the invariant mass is not a physically meaningful quantity"
but I have to think about it some more to get the details right. For starters, though, while there is a magnetic field and no electric field in the frame of the diagram of figure 2, in a moving frame there should be both an electric and a magnetic field. If the magnetic field is taken to be in the x direction, and the motion of the system in the z direction, the electric field should be in the y direction.
The electric field in the moving frame will of course be doing work on the charges.
  • #40
I didn't mean to imply that they used that term. I meant to state that in some places they use the term "mass" to referr to "relativistic mass."
Suppose you're in the inertial frame S where there is a box at rest which is mirrored inside so that photons can bounce back and forth. Let two photons of the same energy be at the center of the box and traveling in opposite directions. Then in S they will hit opposite walls at the same time as measured in S. If you evaluate the "invariant mass" of the two photon system then it will be constant as measured in S. Now move to S' which is moving relative to S. In S' the "invariant mass" will have two different values. That is to say that the "invariant mass" depends on time. As such I've just shown you two different ways of evaluating the "invariant mass" of the system. Yet since it is time dependant it can't be invariant. Hence the term "invariant mass" must be used with caution.
Yep. I agree.
Of course. But nobody said that the mass was conserved or not. In the rest frame of the source if the B-field there will be no electric field and thus no work can be done on a charged particle. When you transform to a new frame moving relative to the first then in that frame work will be done. You'll recall that whether work is done or not will depend on the frame of reference. One wouldn't expect it to be since in general there are external forces which do work and the amount of work will depend on the frame of reference. The energy of the system is conserved in S but not in S'.
Pete
  • #41
To help convince myself of what was going on, I generated some plots of the transverse component of position (the position at right angles to the boost),of a pair of particles moving in a circular path, as per Pete's example #2. If things go well, there will be three jpeg files, showing a plot of the transverse position in the unboosted frame, in the boosted frame, and a plot of the center of mass in the boosted frame.
  • #42
The figure in the page I referred you to was done by a program, i.e. it drew a sinewave. I drew them displaced because the figure would have looked to weird, i.e. too much gunk in too small of a space.
What do you mean by "plot of the center of mass"? How do you define "center of mass"? Do you mean as it is defined here?
http://www.geocities.com/physics_world/sr/center_of_mass.htm
Pete
  • #43
Physicsguru said:
The quick answer is "center of mass of the universe." But, that is too quick of an answer.
There are many inertial reference frames, not just one, and this can be shown.
Suppose that the temperature of the billiard ball is at absolute zero. Thus, there are reference frames in which nothing interior to the ball is moving relative to anything else interior to the ball. Now, pick a point exterior to a billiard ball to be the origin of a coordinate system in which the motion of the system(a billiard ball at absolute zero) is going to be analyzed.
The centre of mass must be the 8-ball itself, there is nothing to 'hang your origin on' otherwise. But how do you define a non-rotating frame other than by the 8-ball itself? In other words can a solitary spherically symmetric ball be seen to rotate in an otherwise empty universe?
Garth
  • #44
Pete
My plots were also computer generated.
What I did exactly is took
x1 := a*cos(w*lambda1);
y1 := a*sin(w*lambda1);
t1 := lambda1;
x2 := -a*cos(w*lambda2);
y2 := -a*sin(w*lambda2);
t2 := lambda2;
This is sufficient to generate the first plot, which is just a plot of a simple sine function, y1 and y2.
Of course I needed specific variable values to do the plot, they were
a=1;w=1;c=1;v=.9;
Obviously y1=-y2, and x1=-x2, and the center of mass is at the origin (x1+x2)/2 = 0, (y1+y2)/2 = 0.
Now comes the interesting part.
I do a boost in the 'x' direction to get
xx1 := a*cos(w*lambda1)-v*lambda1;
yy1 := y1;
tt1 := lambda1-v/c^2*a*cos(w*lambda1);
xx2 := -a cos(w lambda2) - v lambda2;
yy2 := y2;
tt2 := lambda2+v/c^2*a*cos(w*lambda2);
Then I solve tt1=t for lambda1 as a function of time, and tt2=t for lambda2 as a function of time. There was no closed form solution, the computer output was of the "placeholder" form:
lambda1 := (v*a*cos(RootOf(-_Z*c^2+w*v*a*cos(_Z)+w*t*c^2))+t*c^2)/c^2;
lambda2 := -(v*a*cos(RootOf(_Z*c^2+w*v*a*cos(_Z)-w*t*c^2))-t*c^2)/c^2;
With the same values for constants, i.e.
a=1;w=1;c=1;v=.9;
the second plot is a plot yy1 and yy2 as a function of the boosted time t=tt1=tt2, and represents the y-component of the same motion as seen from the frame boosted in the x direction.
The center of mass is just (yy1+yy2)/2. It was stationary in the unboosted frame, but because of the change of the defintion of simultaneity, it moves (quite a bit!) in the boosted frame.
After variable substititions, the appropriate equations for the second plot are fairly simple, they are just
lambda1 := RootOf(-10*_Z+9*cos(_Z)+10*t);
lambda2 := RootOf(10*_Z+9*cos(_Z)-10*t);
yy1 := sin(lambda1);
yy2 := -sin(lambda2);
  • #45
As I proceeded to phase 2, finding the actual momentum and energy, I relaized that I made an unfortunate choice of constants. Sepcifically, I need to change the radius a or the angular velocity w so that a*w < 1 to make the solution physical. The revised position plots (attached) of yyy1 and yyy2 with a=.5 aren't that much different though.
The center of mass of the system in the boosted frame moves, which is a direct consequence of the fact that it isn't an isolated system, external forces are both accelerating it (changing its momentum) and doing work on it (changing its energy).
In the unboosted frame, the external forces at any given instant of time cancel - in the boosted frame, they do not, because of the relativity of simultaneity.
