Relativistic Momentum: Force Accelerating a proton
In summary, the conversation involved finding the necessary force to accelerate a proton at 10^19m/s^2 when the proton already has a velocity of 0.9c. The solution involved using the equations p=gamma * m * U, F = d/dt [gamma * M * U], and F=gamma^3 *m*a to calculate the force. The final answer was 2 * 10^-7 N.
Dr. Science
31
Find the force necessary to give a proton an acceleration of 10^19m/s^2 when the proton has a velocity ( along the same direction as the force) of 0.9c
p=gamma * m * U
F=gamma^3 *m*a
initial momentum = 1/(sqrt(1-0.9c^2/c^2)) * 1.67*10^-27kg * 0.9c = 1.03 *10^-18
guys..
hang on, relief is on its way, I will do it by tonight MST (but I stay up till at least 3 a.m.!).
OK, here we go, 2 glasses of Shiraz or not:
We have F = dp/dt = (d/dt){m0v/(√(1 - v2/c2)}
= m0(d/dt){v/√(1 - v2/c2)}
= m0*du/dt
where u = v/√(1 - v2/c2)
So now du/dt = du/dv*dv/dt where dv/dt = 1e19m/s2
Compute du/dv by standard way, then
du/dt is known as a function of v.
Let v = 0.9c and you have du/dt as a definite number.
Finally F = m0*du/dt
where m0 is the rest mass of a proton.
Make sense?
I think so, the answer I got was 2 * 10^-7 N
Is that correct?
OK, I got
du/dv = v(-1/2)(-2v/c2)[(1 - v2/c2)^(-3/2)] + (1 - v2/c2)^(-1/2)
= 1/(1 - v2/c2)^(1/2) + 0.81/(1 - v2/c2)^(3/2)
= 2.294 + 9.780 = 12.074
Then, F = 12.074*1e19*1.67e-27 = 2.016e-7N
Yay team!
Haha, Thank you so much :)
FAQ: Relativistic Momentum: Force Accelerating a proton
1. What is relativistic momentum?
Relativistic momentum is a concept in physics that takes into account the effects of special relativity, which is the theory that describes the relationship between space and time. It is the product of an object's mass and its velocity, but it also includes a correction factor to account for the speed of light.
2. How is relativistic momentum different from classical momentum?
Classical momentum is calculated by multiplying an object's mass by its velocity, while relativistic momentum also takes into account the effects of special relativity. This means that as an object approaches the speed of light, its relativistic momentum will increase significantly, while its classical momentum will remain the same.
3. How does relativistic momentum affect the force on an object?
The force on an object is directly proportional to its relativistic momentum. This means that as an object's relativistic momentum increases, so does the force on the object. As an object approaches the speed of light, its relativistic momentum and force will become infinite.
4. How is a proton accelerated by a force?
A proton can be accelerated by a force when it is subjected to an electric or magnetic field. These fields exert a force on the proton, causing it to accelerate. The amount of acceleration depends on the strength of the force and the mass and charge of the proton.
5. How does relativistic momentum impact the behavior of a proton at high speeds?
As a proton approaches the speed of light, its relativistic momentum increases significantly. This means that it will require more and more energy to continue accelerating the proton, making it more difficult to reach the speed of light. Additionally, the proton's mass will also increase due to relativistic effects, causing it to require even more energy to accelerate.
