Relativistic momentum in terms of another relativisic momentum
In summary, the conversation involves someone seeking help with a physics problem involving equations and algebraic exercises. They eventually figure out the solution by simplifying the equations and calculating for gamma factors.
Sconlan
When the ship passes at velocity V1, the shuttle pilot measures the magnitude of the momentum of the spaceship to be p1.
On a subsequent mission, the spaceship again passes the shuttle, this time at twice the previous velocity, V2 = 2V1 = 0.840c.
The shuttle pilot again measures the momentum of the spaceship. In terms of p1, what is the magnitude of the measured momentum of the spaceship this time?
The relativistic momentum p of a material particle of mass m and velocity v is defined by the following vector equation:
p=mv/√(1-v^2/c^2 )
The total relativistic energy of a particle m travelling at speed v is given by:
E_tot=(mc^2)/√(1-v^2/c^2) = E_trans+E_mass.
Where:
E_trans = ((mc^2)/(1-v^2/c^2))-mc^2
And
E_mass = mc^2
The relationship between the total relativistic energy and the magnitude of the relativistic momentum can be expressed as:
(E_tot)^2 = p^2c^2+m^2c^4
I feel like this should be pretty straightforward knowing all the equations involved but my brain seems be stalling for some reason.
:welcome:
Time to get your brain into gear! You need to make your best effort before we can help.
Hint. It's a nice algebraic exercise to express ##p_2## in terms of ##p_1##, but you can always do this particular problem numerically.
So far I've solved for p1 (I think) but I can't figure out how to write p2 in terms of p1.
E_tot^2 = (p1^2 c^2) + (m^2 c^4)
p1^2 c^2 = (E_tot^2) - (m^2 c^4)
p1^2 = (E_tot^2 - m^2 c^4) / c^2
p1 = √(E_tot^2 - m^2 c^4 ) / c
Where E_tot = (mc^2) / √(1 - (v^2/c^2) ) = γmc^2
p1 = √((γm^2c^4 ) - (m^2 c^4 )) / c
Isn't ##p_1 = \gamma_1 mv_1##, where ##v_1 = 0.42c##? And ##p_2 = \gamma_2 mv_2##, where ##v_2 = 0.84c##?
Can you just do that numerically (with the ##m## cancelling out)?
Likes nasu
PS if you write ##\dfrac {p_2}{p_1} = \dfrac{\gamma_2 mv_2}{\gamma_1 mv_1} = \dfrac{2\gamma_2}{\gamma_1}## I'm not sure that simplifies much further, so you just have to calculate the two gamma factors.
Thank you, I’d overcomplicated it a ridiculous amount because I was rushing 😖 All sorted now 💆🏻‍♂️
FAQ: Relativistic momentum in terms of another relativisic momentum
What is relativistic momentum?
Relativistic momentum is the momentum of an object when it is moving at a significant fraction of the speed of light. It is given by the formula \( p = \gamma mv \), where \( \gamma \) is the Lorentz factor \( \gamma = \frac{1}{\sqrt{1 - \frac{v^2}{c^2}}} \), \( m \) is the rest mass of the object, and \( v \) is its velocity.
How does relativistic momentum differ from classical momentum?
Classical momentum is given by \( p = mv \), which works well at low velocities. However, as the velocity approaches the speed of light, relativistic effects become significant, and the momentum must be calculated using \( p = \gamma mv \), where the Lorentz factor \( \gamma \) accounts for time dilation and length contraction.
How do you transform relativistic momentum from one reference frame to another?
To transform relativistic momentum from one inertial frame to another, you use the Lorentz transformation equations. If you have momentum \( p \) in one frame moving with velocity \( v \), the transformed momentum \( p' \) in another frame moving with velocity \( u \) relative to the first is given by \( p' = \gamma (p - \frac{uE}{c^2}) \), where \( E \) is the energy of the object and \( \gamma \) is the Lorentz factor for the relative velocity.
What is the relationship between relativistic momentum and energy?
The relationship between relativistic momentum and energy is given by the equation \( E^2 = (pc)^2 + (m_0c^2)^2 \), where \( E \) is the total energy, \( p \) is the relativistic momentum, \( m_0 \) is the rest mass, and \( c \) is the speed of light. This equation shows that energy and momentum are intrinsically linked in relativistic physics.
Why is relativistic momentum important in high-energy physics?
Relativistic momentum is crucial in high-energy physics because particles in accelerators and cosmic rays often move at speeds close to the speed of light. At these high velocities, classical mechanics fails to accurately describe their behavior, and relativistic mechanics must be used to correctly predict outcomes of particle collisions and interactions.
