Relativistic Particle Decay of Higgs Boson
In summary, the homework statement says that a Higgs boson has mass 125 GeV/c2, decaying into a pair of Z bosons, mass 91 GeV/c2. One of the Z bosons in this laboratory frame has kinetic energy -39.14 GeV.
PerfecrtAzian
A Higgs boson has mass 125 GeV/c2, decaying into a pair of Z bosons, mass 91 GeV/c2. In the lab frame, one of the Z bosons is at rest. Determine the kinetic energy for the other Z boson in this laboratory frame.
E = γmc2
γ=1/√(1-β2)
My basic issue surrounding the problem is the derived value for gamma.
First, treating the problem in the center mass frame, I stated:
Mhc2=2γmzc2 thus γ=125Gev/(2*91GeV)= 0.6868
this is where my dilemma lies. Seeing that the Z boson is at rest in the lab frame I assumed γ= 0.6868; however as Kh= (γ-1)E
(0.6868-1)(125 GeV)= -39.14 GeV
What confuses me is that the Kinetic Energy would be negative, thus I assumed my approach to the problem was erroneous. Thus I alternately attempted to derive velocity from gamma in order to perform a lorentz transformation, but then as
γ= 0.6868
v=c√(1-(1/γ2)
there would be a negative within the square root.
If this is the full, exact problem statement, then the problem is very misleading - a Higgs boson with a mass of 125 GeV does not have enough energy to produce two Z bosons with a mass of 91 GeV each, just by energy conservation.
The decay actually happens in nature, but at least one of the Z bosons has to be virtual for that (appear like a less massive Z boson) - and the problem statement doesn't seem to be appropriate to consider this case.
mfb,
Thanks for the feedback. That is what I thought too when reading over this problem myself. The problem is identical to the question posed by my professor, so I wanted to confirm whether it was a personal miscalculation or a general issue with the problem itself.
nrqed said:
But this objection is only valid is the Higgs is initially at rest. Then it cannot decay to two real Z.
It seems clear from the question that the Higgs is not initially at rest in the lab frame and hence there is no problem with the question.
It does not matter if it is at rest or not. The availability of decay channels is independent of the reference frame you use to describe it.
There is always a frame where the Higgs is at rest, where it is easier to see that the decay is not possible (... in the way required here).
You are right, of course. I stand corrected. I should not post at 1 in the morning :-)
Related to Relativistic Particle Decay of Higgs Boson
1. What is the Higgs boson?
The Higgs boson is a fundamental particle in the Standard Model of particle physics. It is responsible for giving other particles their mass through the Higgs mechanism.
2. Why is the decay of the Higgs boson important?
The decay of the Higgs boson is important because it allows us to study the properties of this elusive particle and confirm its existence. It also helps us better understand the fundamental forces and interactions in the universe.
3. How does the Higgs boson decay?
The Higgs boson can decay into different particles depending on its energy and other factors. The most common decay channels are into two bottom quarks or two W or Z bosons.
4. What is the significance of relativistic particle decay?
Relativistic particle decay refers to the decay of particles at high speeds, approaching the speed of light. This is important because it allows us to study the behavior of particles under extreme conditions and test the predictions of relativity.
5. What can we learn from studying the relativistic particle decay of the Higgs boson?
Studying the relativistic particle decay of the Higgs boson can provide us with valuable information about the properties of this particle, such as its mass and spin. It can also help us test the predictions of the Standard Model and potentially discover new physics beyond it.
