Relativistic Quantum Mechanics vs Quantum Field Theory
In summary, relativistic quantum mechanics and quantum field theory are two different approaches to describing particles and their interactions in a relativistic framework. In relativistic QM, the number of particles is fixed while in QFT it can vary. QFT also deals with fields as the corresponding classical objects, while relativistic QM uses relativistic particles. While relativistic QM allows for particle creation and annihilation, this is not the case in QFT, where even states with an uncertain number of particles can exist. While the Hamiltonian in relativistic QM and QFT is not Lorentz invariant, it is necessary to express it in a relativistic form in both theories.
Tio Barnabe
What's the difference between relativistic quantum mechanics and quantum field theory?
In principle, my guess is that to do the former, one needs to express the Hamiltonian in a relativistic, Lorentz invariant, form, because it seems to be the only frame-related term in the wave equation.
(Is that correct?)
Would quantum field theory be everything we do after this procedure?
One (slightly oversimplified) answer is that in relativistic QM the number of particles is fixed, while in QFT it does not need to be so. (Now @vanhees71 will tell you that relativistic QM is wrong, but that is not an answer to your question.)
Another answer concerns the classical objects that the quantum theory attempts to quantize. In relativistic QM the corresponding classical objects are relativistic particles. In QFT the corresponding classical objects are fields.
because relativistic energy allows for creation and anihilation of particles, correct?
Not exactly. Even if there is no enough energy to create new particles, in QFT you can have a state with an uncertain number of particles.
That's wrong, the Hamiltonian is never Lorentz invariant, neither in relativistic QM nor in QFT.
The most obvious relativistic QM theory is S-matrix theory which does indeed allow for particle creation and annihilation and is quite independent of field theory. The creation and annihilation of particles follows in relativistic QM from the same principles that allow chemical reactions. Although you can, if you wish, derive S-matrix properties from field theory, it isn't necessary. S-matrix theory, per se, stands by itself and was the basis of the concept of "particle democracy" and the ground from which string theory was developed.
Likes Demystifier
Related to Relativistic Quantum Mechanics vs Quantum Field Theory
What is the difference between Relativistic Quantum Mechanics and Quantum Field Theory?
Relativistic Quantum Mechanics is a theory that combines the principles of quantum mechanics and special relativity to describe the behavior of particles at high speeds. Quantum Field Theory, on the other hand, is a more advanced theory that describes not just individual particles, but the interactions between them and their surrounding fields.
Which theory is more accurate for describing phenomena at the subatomic level?
Quantum Field Theory is generally considered to be more accurate for describing phenomena at the subatomic level. This is because it takes into account the full range of interactions between particles and their surrounding fields, while Relativistic Quantum Mechanics only considers the behavior of individual particles.
Can Relativistic Quantum Mechanics and Quantum Field Theory be used together?
Yes, these two theories can be used together in certain situations. Relativistic Quantum Mechanics can be seen as a simplified version of Quantum Field Theory, and can be used to make predictions in cases where the full complexity of Quantum Field Theory is not necessary.
What are the main challenges in developing a unified theory that combines Relativistic Quantum Mechanics and Quantum Field Theory?
One of the main challenges in developing a unified theory is the mathematical complexity involved in combining these two theories. Additionally, there are still unanswered questions and discrepancies between the two theories, such as the incompatibility of gravity in the framework of Quantum Field Theory.
What practical applications do Relativistic Quantum Mechanics and Quantum Field Theory have?
Both theories have a wide range of practical applications in fields such as particle physics, quantum chemistry, and materials science. They have helped to explain and predict the behavior of particles and their interactions, leading to advancements in technology and our understanding of the universe.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
