Relativistic relative velocity
In summary: I think it's okay now.]In summary, the relativistic relative velocity of two particles moving near the speed of light can be derived using Lorentz transformations. By considering two inertial observers in "standard configuration," with one moving in the positive x-direction of the other, and using the transformation formulas for velocity components, we can determine that the relative velocity is given by ##\vec{\beta} \, ^{\prime} = \left( \frac{\beta_x - \beta_{rel}}{1 - \beta_x \beta_{rel}} \right) \hat{\imath}^\prime \qquad \vec{\beta} = \left( \frac{\beta_x^\prime + \beta_{rel}}
davidge
554
I'm interested in deriving the relativistic relative velocity of two particles moving near the speed of light. It turns out to be (with ##c = 1##) $$\frac{V^{(1)} - V^{(2)}}{1 - V^{(1)}V^{(2)}}$$
How should I approach to this problem? Maybe I should not think of particles at all, but instead simply to consider the two reference frames as two set of coordinate values? So
Frame 1: ##(x^0,x^1,...)##; Frame 2: ##(y^0,y^1,...)##.
Then the velocities are ##\partial x^i / \partial t## and ##\partial y^i / \partial t'##.
##t \equiv x^0##, ##t' \equiv y^0##
Now, ##dy^\alpha = \Lambda^\alpha{}_{\beta}dx^\beta##. The solution for the ##\Lambda## are easy for the case when the displacement ##dx^i## are null in one of the frames, but this does not help in solving for the situation in question.
davidge said:
I'm interested in deriving the relativistic relative velocity of two particles moving near the speed of light. It turns out to be (##c = 1##) $$\frac{V^1 - V^2}{\sqrt{1 - V^1V^2}}$$
First, check that expression. Is the square root there?
One could derive it from a Lorentz Transformation, probably with the aid of a spacetime diagram.
Using rapidity is quicker and more geometrical.
One can also use vector-algebraic methods with dot products.
Could you give me a hint ?
Oh, there's no sqrt in the expression. Thanks.
One way to start off is like this:
##\hat t_{1}=\cosh(\theta_1-\theta_0) \hat t_0 + \sinh(\theta_1-\theta_0)\hat t_{0,\perp}=\cosh(\theta_1-\theta_0)\left( \hat t_0 + \tanh(\theta_1-\theta_0)\hat t_{0,\perp}\right)##
##\hat t_{2}=\cosh(\theta_2-\theta_0) \hat t_0 + \sinh(\theta_2-\theta_0)\hat t_{0,\perp}##
then what you seek is in here
##\hat t_{2}=\cosh(\theta_2-\theta_1) \hat t_1 + \sinh(\theta_2-\theta_1)\hat t_{1,\perp}##
..to be expressed in terms of the preceding.
[You could simplify the notation by writing ##\theta_{21}\equiv\theta_{2}-\theta_{1}##].
One might not use the trig functions from the start... it can be deduced later, if desired.
So, ##\hat t_1=\gamma_{10}(\hat t_0 + \beta_{10} \hat t_{0,\perp})##... but that already gives a hint.
A purist might start with
##\hat t_1=A\hat t_0 + B\hat t_{0,\perp}## and deduce that ##\hat t_1=A(\hat t_0 + V\hat t_{0,\perp})## is a useful form when interpreted physically.
Likes davidge
This formula is only true for particles moving along the same direction in the given reference frame. The relative velocity in general is defined as the velocity of one particle in the restframe of the other particle (of course the latter must be massive if the definition should make sense). For details, see p. 16 of
http://th.physik.uni-frankfurt.de/~hees/pf-faq/srt.pdf
Thanks @robphy for your contribution
I've read it
In this case, would we end up with ##\Lambda^0{}_{0} = \gamma##, ##\Lambda^i{}_{0} = v^i \gamma##? (Where ##v^i## denotes the i-th component of the velocity)
The method here is relatively straightforward, but you need to use notation in a way that won't confuse you. Subscripts can help.
Say we have two inertial observers in "standard configuration," so that the "primed" observer is moving in the "unprimed" observer's positive x-direction. Then the Lorentz transformations are:
##\mathrm{d}x^{\prime} = \dfrac{\mathrm{d}x - \beta_{rel} \, c \, \mathrm{d}t}{\sqrt{1 - \beta_{rel}^2}} \qquad \mathrm{d}x = \dfrac{\mathrm{d}x^{\prime} + \beta_{rel} \, c \, \mathrm{d}t^{\prime}}{\sqrt{1 - \beta_{rel}^2}} \\
\mathrm{d}y^{\prime} = \mathrm{d}y \\
\mathrm{d}z^{\prime} = \mathrm{d}z \\
c\, \mathrm{d}t^{\prime} = \dfrac{c \, \mathrm{d}t - \beta_{rel} \, \mathrm{d}x}{\sqrt{1 - \beta_{rel}^2}} \qquad c\, \mathrm{d}t = \dfrac{c \, \mathrm{d}t^{\prime} + \beta_{rel} \, \mathrm{d}x^{\prime}}{\sqrt{1 - \beta_{rel}^2}}##
where ##\beta_{rel}## is the (normalized) relative speed of the observers (##v_{rel}/c##). Note that ##\beta_{rel} < 1## (because observers cannot travel at the speed of light).
Now say there's something else that's moving with velocity ##\vec{\beta} = (\beta_x, \beta_y, \beta_z)## according to the "unprimed" observer, and ##\vec{\beta} \, ^{\prime} = (\beta_x^{\prime}, \beta_y^{\prime}, \beta_z^{\prime})## according to the "primed" observer (no "rel" subscript now). It could even be something traveling at the speed of light.
Our goal is to find the transformation formulas for these primed and unprimed velocity components. Specifically, you're looking for the transformation of the ##\beta_x##-component, since the relative motion of our observers is along their coincident ##x##-axes.
Well, we just use the fact that ##\beta_x = \frac{\mathrm{d}x}{c \, \mathrm{d}t}##, etc.:
##\beta_x^{\prime} = \dfrac{\mathrm{d}x^\prime}{c \, \mathrm{d}t^\prime} = \dfrac{\frac{\mathrm{d}x - \beta_{rel} \, c \, \mathrm{d}t}{\sqrt{1 - \beta_{rel}^2}}}{\frac{c \, \mathrm{d}t - \beta_{rel} \, \mathrm{d}x}{\sqrt{1 - \beta_{rel}^2}}} = \dfrac{\mathrm{d}x - \beta_{rel} \, c \, \mathrm{d}t}{c \, \mathrm{d}t - \beta_{rel} \, \mathrm{d}x}##
Divide top and bottom by ##c \, \mathrm{d}t##, and we have:
##\beta_x^{\prime} = \dfrac{\beta_x - \beta_{rel}}{1 - \beta_x \beta_{rel}}##.
The same procedure generates the inverse transformation:
##\beta_x = \dfrac{\beta_x^\prime + \beta_{rel}}{1 + \beta_x^\prime \beta_{rel}}##.
Since these are vector components, they can be positive or negative. They are not speeds! The only speed here is ##\beta_{rel}##.
If you follow the same procedure for the primed and unprimed ##y##- (or ##z##-) components, you'll find that ##\beta_y^\prime \neq \beta_y##. So even the velocity-components perpendicular to the observers' axis of relative motion get transformed. That's not so in Galilean relativity!
In the special case that ##\beta_y = \beta_y^\prime = \beta_z = \beta_z^\prime = 0##, the ##x##-component is the only relevant one, and we can say:
##\vec{\beta} \, ^{\prime} = \left( \dfrac{\beta_x - \beta_{rel}}{1 - \beta_x \beta_{rel}} \right) \hat{\imath}^\prime \qquad \vec{\beta} = \left( \dfrac{\beta_x^\prime + \beta_{rel}}{1 + \beta_x^\prime \beta_{rel}} \right) \hat{\imath}##,
where ##\hat{\imath}## is the basis vector ##(1, 0, 0)##.
That's the familiar formula you were looking for. I kept the vector notation because there is sometimes confusion over what's a speed, what's a velocity, and what's a velocity-component. The value of what's in the parentheses can be positive or negative, since it's really the ##x##-component of the velocity vector. Its absolute value is the speed (the magnitude of the velocity). So ##\left| \beta_x \right| = \| \vec{\beta} \| = \beta## and ##\left| \beta_x^\prime \right| = \| \vec{\beta} \, ^\prime \| = \beta^\prime##.
Note that if ##\beta = 1## here, then so does ##\beta^\prime## (and vice versa). And always remember that ##\beta_{rel} < 1##.
[Edited because I got confused myself a bit at the end there!]
Likes davidge
Thank you SiennaTheGr8. This was very helpful. I don't understand just why the transformation for the "spatial part", ##dx'##, is given by your expression above. Since ##dx'\ ^i = \Lambda^i{}_{j}dx^j##, if the ##dx^j## are not equal to zero, I thought we would have a different expression for ##dx'## than the one that you wrote down.
You mean at the very top of my post? That's just the standard Lorentz transformation for space and time coordinates (rather, the differentials thereof).
By the way, I did edit my post just now because I'd made an error at the end.
First, one needs some basic formula from special relativity. I'd suggest Bondi's K-calculus as one of the easiest approaches. This can be found in Bondi's book, "Relativity and common sense".
The key result from Bondi's analysis is a relationship between the doppler shift factor k, and the velocity v. I'll give the result initially without proof:
$$ \beta = \frac{k^2 - 1}{k^2 + 1} \quad k = \sqrt{\frac{1+\beta}{1-\beta}}$$
Here I've given both ##\beta=v/c## as a function of the doppler shift factor k, and k as a function of ##\beta##. Wiki has the later formula, in their article on "Relativistic doppler effect" <link>.
The relativistic Doppler effect is the change in frequency (and wavelength) of light, caused by the relative motion of the source and the observer (as in the classical Doppler effect), when taking into account effects described by the special theory of relativity.
If you send out a 1 hz signal, i.e. one flash of light per second, from observer 1, then observer 2 will receive one flash every 2 seconds if k=2. This happens at a velocity v = 3/5c, or ##\beta = .6##.
A third observer, moving at the same velocity relative to the second observer as the second has relative to the first, must receive one flash every four seconds. Basically, the doppler k-factors must multiply.
It remains only to do some algebra. If you substitute
$$\beta_1 = \frac{k_1^2 -1}{k_1^2 + 1} \quad \beta_2 = \frac{k_2^2 - 1}{k_2^2 + 1}$$
into
$$\beta_T = \frac{\beta_1 + \beta_2}{1 + \beta_1 \beta_2}$$
you get
$$\beta_T = \frac{(k1\,k2)^2 -1}{ (k1\,k2)^2 +1 }$$
which shows that this formula makes the doppler factor k's multiplicative, which is the correct behavior.
I'm torn as to whether or not to present a proof of the relationship between k and ##\beta##. The proof isn't that hard, but I think to properly understand it would take a more detailed description than I have the patience to write. Since Bondi (and other authors) have already done a much better write-up than I could do in a short post, I think it might be best if I defer the details to another source, with possibly a post if this turns out to be hard to track down. If you can't get a hold of Bondi's original book, try googling for "bondi k-calculus". It's not really calculus, by the way - just algebra.
The point I'm hoping to get across is the following basic logic. Velocity can be computed knowing the doppler shift factor k, and vica-versa. The doppler shift k factors must multiply. This gives us the "velocity addition rule".
Likes m4r35n357 and davidge
Bondi's method is great for physical motivation.
I never liked the Lorentz-transformation approach involving dividing "differentials".
Underlying Bondi's multiplicative result that Doppler factors multlply ##k_{20}=k_{21}k_{10}##
is that since ##k=e^\theta##, we have the additivity of rapidities ##\theta_{20}=\theta_{21}+\theta_{10}##
so that the relative-rapidity is ##\theta_{21}=\theta_{20}-\theta_{10}## or simply ##\theta_{rel}=\theta_{2}-\theta_{1}##.
Since physics prefers velocities (slopes) over rapidities (angles),
this suggests ##v_{rel}=\tanh{\theta_{rel}}=\tanh\left(\theta_{2}-\theta_{1}\right) \equiv
\frac{\tanh \theta_{2}-\tanh\theta_{1}}{1-\tanh\theta_2\tanh\theta_1}=\frac{v_2-v_1}{1-v_2v_1}##,
where we used a mathematical identity.
Indeed many of the formulas in special relativity are hyperbolic-trigonometric identities written in terms of ##\tanh\theta##
(as if you took all of the trig formulas from ordinary geometry and wrote them in terms of the slope ##m##... example: write ##\cos\theta## in terms of ##\tan\theta##.).
Once you realize that... a lot of the mathematical mystery goes away [if you accept the model of Minkowski spacetime]...
if not, at least you can be guided by your ordinary trigonometric intuition rather than hunting around for how to do algebra with ##\gamma## and ##v##.
It might be worth stating that
the Doppler factor ##k## is an eigenvalue of the Lorentz boost... so, it is arguably more important mathematically than the velocity.
And writing a composition of boosts in the eigenbasis [light-cone coordinates] immediately leads to Bondi's multiplicative result.Since I'm thinking about it:
##k=e^\theta=\cosh\theta+\sinh\theta=\cosh\theta(1+\tanh\theta)=\gamma(1+v)##
##1/k=e^{-\theta}=\cosh\theta-\sinh\theta=\cosh\theta(1-\tanh\theta)=\gamma(1-v)##
By multiplication, ##1=\gamma^2(1-v^2)##.
By division, ##k^2=e^{2\theta}=\frac{1+v}{1-v}##.
Half-the-difference is ##\frac{1}{2}(k-k^{-1})=\sinh\theta=\cosh\theta \tanh\theta=\gamma v##.
Half-the-sum is ##\frac{1}{2}(k+k^{-1})=\cosh\theta=\gamma##.
The ratio is ##v=\tanh\theta=\frac{k-k^{-1}}{k+k^{-1}}=\frac{k^2-1}{k^2+1}##.
Yes. Can you show me the derivation of that expression for ##dx'##?
Thanks Pervect and Robphy. I will carefully read your posts and look on the internet for the Bondi's analysis, but I think it's easier (for me) to derive the expressions from the Lorentz transformation method.
To be clear, in the aforementioned special case we have:
##\beta^\prime = \left| \beta_x^\prime \right| = \left| \dfrac{\beta_x - \beta_{rel}}{1 - \beta_x \beta_{rel}} \right| = \dfrac{\left| \beta_x - \beta_{rel} \right|}{\left| 1 - \beta_x \beta_{rel} \right|} \qquad \beta = \left| \beta_x \right| = \left| \dfrac{\beta_x^\prime + \beta_{rel}}{1 + \beta_x^\prime \beta_{rel}} \right| = \dfrac{\left| \beta_x^\prime + \beta_{rel} \right|}{\left| 1 + \beta_x^\prime \beta_{rel} \right|}##.
But perhaps it's worth emphasizing that the absolute value of a sum (or difference) of two terms does not generally equal the sum (or difference) of the absolute values of the terms. So we can't just isolate ##\left| \beta_x \right|## and ##\left| \beta_x^\prime \right|## on the right sides of those expressions and sub in ##\beta## and ##\beta^\prime## for them.
In other words, in the special case that ##\beta_y = \beta_y^\prime = \beta_z = \beta_z^\prime = 0##, it is still NOT generally true that:
##\beta^\prime = \dfrac{\beta - \beta_{rel}}{1 - \beta \beta_{rel}} \qquad \beta = \dfrac{\beta^\prime + \beta_{rel}}{1 + \beta^\prime \beta_{rel}}##.
These often-seen formulas only hold if ##\beta_x^\prime## isn't negative. Either way, though, ##\left| \beta_x \right| = \beta## and ##\left| \beta_x^\prime \right| = \beta^\prime##, and the sign of the ##x##-component of course specifies the vector's direction in either frame.
Hope I've got that all right. :confused:
Likes davidge
@davidge, are you already comfortable with the Lorentz transformation for coordinates? Namely:
##x^{\prime} = \dfrac{x - \beta ct}{\sqrt{1 - \beta^2}} \qquad x = \dfrac{x^{\prime} + \beta ct^{\prime}}{\sqrt{1 - \beta^2}} \\
y^{\prime} = y \\
z^{\prime} = z \\
ct^{\prime} = \dfrac{ct - \beta x}{\sqrt{1 - \beta^2}} \qquad ct = \dfrac{ct^{\prime} + \beta x^{\prime}}{\sqrt{1 - \beta^2}}##
If you are, then use those formulas to derive the transformation for ##\Delta x = x_2 - x_1## (etc.). The differentials are just infinitesimal changes in the coordinates, so you can then just swap the deltas for d's.
To save you the trouble: the differential transformation looks identical to the coordinate transformation, except with the d's tossed in.
By introducing "speed" instead of just keeping the [signed] x-component ##\beta_x##,
it seems your equations are unnecessarily complicated and restrictive.
There is no restriction that you use the relative-"speed"... if you do, it's best to make that explicit in the formula with ##|\beta|##.
Using "speed" in the Lorentz transformations is like saying that a rotation can only involve a positive angle.
By using "speed", you end up claiming...
Those often-seen formulas are fine
if you stick with x-components of velocity and x-components of relative-velocity, as is usually done.
yea
Well, I know how to derive them only for the case where the spatial displacements ##\bf{dx}## are equal to zero in one of the frames:
Let's suppose a particle is seen stationary in the unprimed frame, but has velocity of magnitude ##v'## in the primed frame. So all ##dx^i## are equal to zero, and we have the transformation equations:
dx'^{{\ }i} = \Lambda^i{}_{0}dt \\
dt' = \Lambda^0{}_{0}dt$$
The velocity i-th component is ##dx'^{{\ }i} / dt'##. So, dividing the above, we get
$$v'^{{\ }i} \Lambda^0{}_{0} = \Lambda^i{}_{0}$$
Aditionally, we have
$$\Lambda^\alpha{}_{\sigma}\Lambda^\beta{}_{\kappa}\eta_{\alpha \beta} = \eta_{\sigma \kappa}$$
Therefore
$$-1 = -(\Lambda^0{}_{0})^2 + \sum_i (\Lambda^i{}_{0})^2\\$$
The solution is
$$\Lambda^0{}_{0} = \frac{1}{\sqrt{1-v'^2}} \\
\Lambda^i{}_{0} = \frac{v'^{{\ }i}}{\sqrt{1-v'^2}}$$
And we can write the ##dx'^{{\ }i}## as
$$dx'^{{\ }i} = \frac{v'^{{\ }i}}{\sqrt{1-v'^2}}dt$$
We can see that this last expression is different from the one that you wrote for the ##dx'##. Probably it's because I've assumed that the particle is at rest in one of the frames. I don't know how to derive it for the case where the particle is moving in both frames, because in that case we would have a long summ in the transformation equations, not just one term as in above.
@robphy
Thanks for the response.
I find the full vector equations clearer, more illuminating, and certainly less restrictive (perpendicular components!).
As opposed to a third ##x##-component, do you mean?
I may be mistaken, but I believe that there is an implied restriction that ##w## be a "relative speed" in the often-seen ##v = (u - w) / (1 - uw/c^2)##. The inverse equation is ##u = (v + w) / (1 + vw/c^2)##, so: if "##v## guy" subtracts ##w##, and "##u## guy" adds it, doesn't it have to be an unsigned magnitude? Additionally, we have the requirement that ##w \neq c##, but no such requirement of ##v## and ##u##.
As for being explicit about speed vs. velocity vs. velocity-components, I agree, and that's actually why I prefer the full vector equations!
But what else could the ##v## (or ##\beta##) in the Lorentz transformations be, other than relative speed?
"As is usually done"—I don't think that most presentations are particularly clear about what's a speed, what's a velocity, and what's a velocity-component. That's one reason why I prefer the full vectorial approach.
SiennaTheGr8 said:
From a text search on that page, all references to "speed" are for "speed of light"... not to any particle or frame.
On the other hand, "velocity" is used throughout.
SiennaTheGr8 said:
@robphy
agreed... but one doesn't have to overcomplicate it.
A good consistent notation might suffice, as in the wikipedia article you suggested.
SiennaTheGr8 said:
@robphy
I'll address this later.
SiennaTheGr8 said:
@robphy
relative-velocity, where ##v## can have any sign (or ##v_x## to be explicit).
If you want speed, then you probably should be explicit with ##|\vec v|##.
Can ##x## and ##t## take arbitrary signs?
I'll ask again more explicitly...
if you write down a rotation transformation in euclidean space,
is the transformation parameter "the angle" or "the magnitude of the angle"?
If you write the Lorentz Transformation as a matrix,
you can compose transformations and see the group properties.
With magnitudes, I think you lose that ability.
For rotations in the plane, if i compose a rotation by 30-degrees and then by (-30)-degrees, I should get the identity.
In "slope form" (where the parameter is the slope ##m=\tan\theta## instead of angle), these correspond to ##m_A=\tan 30## and ##m_B=-\tan(30)##.
If I use magnitudes, I don't think you get that... unless you say, "for clockwise rotations, you have to use this other form of the transformations".
The same argument applies to the Lorentz Transformations.
Implicit in this discussion is that their axes have the same handedness... in a boost, we're not looking at each other in a mirror of some kind.
We agree on the general direction of "large x".
Technically speaking, we agree that the positive x-axis (in spacetime) of one observer projects onto the positive x-axis of the other. (As vectors in spacetime [in a spacetime diagram], their x-axes are not parallel.)
Related to Relativistic relative velocity
What is relativistic relative velocity?
Relativistic relative velocity is the concept of how the velocity of one object appears to another object that is moving at a different velocity, taking into account the effects of special relativity.
How is relativistic relative velocity different from classical relative velocity?
Classical relative velocity only takes into account the velocities of two objects in relation to a stationary observer, whereas relativistic relative velocity takes into account the velocities of both objects in relation to each other.
What is the formula for calculating relativistic relative velocity?
The formula for calculating relativistic relative velocity is v = (u + v) / (1 + (uv / c^2)), where v is the relative velocity, u is the velocity of the first object, v is the velocity of the second object, and c is the speed of light.
What is the significance of the speed of light in relativistic relative velocity?
The speed of light, c, is a fundamental constant in the formula for relativistic relative velocity and is the maximum possible velocity that any object can reach. This means that no object can ever exceed the speed of light, and as an object approaches the speed of light, its relativistic relative velocity approaches infinity.
How does relativistic relative velocity affect time and space?
According to the theory of special relativity, as an object's velocity approaches the speed of light, time slows down and space contracts. This means that an observer on a fast-moving object would experience time passing slower and distances appearing shorter compared to an observer at rest.
