Relativistic rotational kinetic energy
In summary, the conversation discusses the formula for rotational energy and its validity for relativistic velocities. It also mentions the expressions for linear momentum and angular velocity, and how they are affected by relativistic modifications. Ultimately, it is concluded that kinetic energy and relativistic mass are not useful concepts in special relativity, and the exact formula for total energy is E = mc2 √(1 + γ2v2/c2). For circular motion, this can be simplified to KE = mc2(√(1 + γ2v2/c2) - 1) by substituting v = ω/r.
johne1618
371
Hi,
I was wondering if the formula for rotational energy:
E = 1/2 * L * w
where L is the angular momentum and w is the angular velocity,
is actually correct for relativistic velocities.
Using
L = p * r
and
w = v / r
where
p = the linear momentum = m * v
We get:
E = 1/2 * (m * v * r) * (v/r)
I would have thought that this expression is correct up to relativistic velocity as the expressions for linear momentum, p = m * v, and angular velocity, w = v / r, do not require relativistic modification provided that we acknowledge that m increases as v -> c.
As a corollary, as v -> c, it seems that the maximum rotational energy of a system is:
E = 1/2 * m c^2 (i.e. half the total mass/energy of the system)
John
Kinetic energy is not a particularly useful concept in special relativity. Neither is the 'relativistic mass.' Always use the rest mass and put in the factors of γ explicitly. The exact formula for the total energy of a particle is E2 = m2c4 + p2c2 where p = γmv. This can be written
The kinetic energy will be the total E minus the rest energy:
This is still exact. For circular motion, just put in v = ω/r.
Related to Relativistic rotational kinetic energy
What is relativistic rotational kinetic energy?
Relativistic rotational kinetic energy is the energy possessed by a rotating object due to its motion and relativistic effects. It takes into account both the rotational velocity and the speed of light, as described by Einstein's theory of relativity.
How is relativistic rotational kinetic energy calculated?
The formula for relativistic rotational kinetic energy is E = mc²(γ-1), where E is the energy, m is the mass of the object, c is the speed of light, and γ is the Lorentz factor. The Lorentz factor takes into account the relativistic effects of velocity on an object's mass.
What is the difference between classical and relativistic rotational kinetic energy?
Classical rotational kinetic energy only takes into account the rotational velocity of an object, while relativistic rotational kinetic energy also considers the effects of high speeds and the speed of light. As an object approaches the speed of light, its mass increases and therefore its rotational kinetic energy also increases according to the formula E = mc²(γ-1).
What are some real-world applications of relativistic rotational kinetic energy?
Relativistic rotational kinetic energy has important applications in fields such as particle physics, where high-speed particles are accelerated and their relativistic effects must be taken into account. It also plays a role in astrophysics, where the rotation of massive objects such as black holes can have significant relativistic effects.
Can relativistic rotational kinetic energy be converted into other forms of energy?
Yes, relativistic rotational kinetic energy can be converted into other forms of energy, such as heat or electromagnetic radiation. This conversion can occur through various processes, such as friction or interactions with other particles, and is governed by the laws of thermodynamics.
9K
