Relativistic Velocity, Perp. Accel., Momentum: Explained
In summary: This can also be seen as a simple consequence of the time dilation formula. The time a clock at rest in ##\Sigma'##, which is at the particle's position at some time, is ticking slower than a clock at the same position in ##\Sigma##, which is at rest wrt. to the clock in ##\Sigma##. This means that the velocity will be measured as being smaller. This is exactly what we see in the above expression, except that we have to multiply with the speed of light to get it dimensionally correct, as the original velocity was given in units where c=1.In summary, when an observer accelerates eastward to a velocity v in an inertial frame, the total velocity of a
em3ry
A stationary observer sees a particle moving north at velocity v very close to the speed of light. Then the observer accelerates eastward to velocity v. What is its new total velocity of the particle toward the north-west relative to the observer?
I ask because while the particles total velocity will be higher its velocity northward will be lower. It is counterintuitive that accelerating a particle in one direction will decrease its velocity in another.
Will its momentum in the north direction also be lower? I am sure it won't but why not? (because gamma increases?). How does the math work out?
If I understand you right, you have a particle moving with a velocity ##\vec{v} =v \vec{e}_x## wrt. to an inertial frame ##\Sigma## and you want to know its velocity in an inertial frame which moves with a velocity ##\vec{w}=w \vec{e}_y##.
It's easier to work first with four-vectors. The particle's four-velocity components wrt. to ##\Sigma## are
$$u^{\mu}=\gamma_v (1,\beta_v,0,0).$$
The components wrt. ##\Sigma'## are given by a Lorentz boost in ##y##-direction with velocity ##\vec{w}##, i.e., for the four-vector components you have
$$u^{\prime \mu}=[\gamma_w (u^0-\beta_w u^2),u^1,\gamma_w(-\beta_w u^0 + u^2),u^3]= \gamma_v (\gamma_w,\beta_v,-\beta_w \gamma_w,0).$$
The three-velocity thus is
$$\vec{v}'=c \vec{u}'/u^{\prime 0}=\frac{c}{\gamma_v \gamma_w} (\gamma_v \beta_v,-\gamma_v \beta_w \gamma_w,0)=(v/\gamma_w,-w,0).$$
Likes PeroK, etotheipi and em3ry
So the momentum in the north direction (##e_x##) becomes ## \gamma_v \gamma_w \cdot v / \gamma_w ##? The same as it was before? (Times the mass of course and c I guess)
So its velocity in the north direction slowed down by ##\gamma_w##. Exactly the amount its internal clock slowed down! (As measured by the observer)
Relativity is weird!
The coordinates in the N direction are the same for both frames, as this direction is perpendicular to the relative motion. If we imagine the particle traveling a distance ##d## in the N-direction while its internal clock (proper time) advances by ##\tau##, then the N-component of the particle's velocity is directly related to the particle's time dilation as measured in the two frames.
In other words, if ##u_N, u'_N## is the N-component of the particle's velocity in the two frames and ##\gamma, \gamma'## is the particle's gamma factor in the two frames, then the speed in the N-direction as measured in the two frames is: $$v = \frac{d}{\gamma \tau} \ \ \text{and} \ \ v' = \frac{d}{\gamma' \tau}$$
Likes em3ry
That follows automatically, as four-momentum is a four-vector: ##p^x = p'^x##.
Where: ##p^x = \gamma m v^x## and ##p'^x = \gamma' m v'^x##.
Likes em3ry
For a boost perpendicular to the velocity in ##\Sigma## all there is, is time dilation for the velocity component in the original direction, which explains the rescaling with ##1/\gamma_w## of this component.
Likes em3ry
Related to Relativistic Velocity, Perp. Accel., Momentum: Explained
1. What is relativistic velocity?
Relativistic velocity, also known as relativistic speed, is the velocity of an object in relation to the speed of light. It takes into account the effects of special relativity, which states that the speed of light is the same for all observers regardless of their relative motion.
2. How is perp. accel. (perpendicular acceleration) related to relativistic velocity?
Perpendicular acceleration is a component of an object's acceleration that is perpendicular to its velocity. In the context of relativistic velocity, it refers to the acceleration an object experiences as it moves at high speeds and changes direction. This type of acceleration is affected by the object's relativistic velocity.
3. What is momentum in relation to relativistic velocity?
Momentum is a measure of an object's motion and is defined as the product of an object's mass and its velocity. In the context of relativistic velocity, momentum takes into account the effects of special relativity and is calculated using the relativistic mass and velocity of an object.
4. How is relativistic velocity, perp. accel., and momentum explained?
Relativistic velocity, perpendicular acceleration, and momentum are all concepts that are explained by the theory of special relativity. This theory describes how time, space, and motion are perceived differently by observers in different frames of reference, especially at high speeds. These concepts are used to understand the behavior of objects moving at relativistic velocities.
5. What are some real-world applications of understanding relativistic velocity, perp. accel., and momentum?
Understanding these concepts is crucial in many fields, including astrophysics, particle physics, and engineering. For example, the behavior of particles in particle accelerators, the motion of objects in space, and the design of high-speed vehicles all rely on a thorough understanding of relativistic velocity, perpendicular acceleration, and momentum.
