Relativity and Spatial Dimension
In summary, mass influences the 'shape' of three dimensional space plus time, but this doesn't require a further or higher spatial dimension.
ajjjja
If mass influences the 'shape' of three dimensional space plus time, does that require a further or higher spatial dimension, or is that unnecessary?
Mass doesn't determine the structure of spacetime; matter does. Mass is simply defined as, "a resistance to a change in motion" and nothing more.
BTW, why don't three spatial dimensions work just fine? Why an additional spatial dimension?
General Relativity states that the presence of mass/energy changes the geometry of spacetime. We have three (noneuclidean) spatial dimensions and one time dimension--for a total of 4, and that's it for general relativity.
You might be intrigued by something called "Kaluza-Klein" theory. By incorporating another spatial dimension into general relativity, Kaluza managed to derive the laws of electromagnetism.
M-theory's up to 11 or so, last I heard...
If I correctly understand what you're asking, no, an extra dimension is not necessary.
You may be thinking of curved 2D surfaces as an example. For example, a sphere. I'm guessing that you can't imagine how one could have a 2D surface that is curved like the surface of a sphere without there being some higher-dimensional space for the full sphere to live in. Am I on the right track?
If so, I don't blame you, since this is a tricky idea to get used to, but it is in fact possible to have, say, a spherically curved 2D surface without there being a whole 3D sphere. You can actually measure the curvature of a surface without leaving the surface itself. The method for doing so is, roughly speaking, to measure how the distance between two points depends on the path you take between those points. Alternatively, you can measure the ratio of the diameter of a circle to its circumference, or the sum of the angles of a triangle, or other geometric things like that. In "flat" space they have the normal values we're used to (pi, or 180 degrees, respectively), but in "curved" (I prefer "distorted") space you will notice some different numbers. Still, these sorts of measurements are based only on the space itself, so there's no need to have any higher dimension.
FAQ: Relativity and Spatial Dimension
What is relativity?
Relativity is a theory developed by Albert Einstein in the early 20th century that explains the relationship between space and time. It states that the laws of physics are the same for all observers, regardless of their relative motion.
How does relativity relate to spatial dimension?
Relativity states that space and time are interconnected and can be affected by the presence of massive objects. It also suggests that the three-dimensional space we perceive is actually part of a larger four-dimensional spacetime continuum.
What are the main principles of relativity?
The main principles of relativity are the principle of relativity, which states that the laws of physics are the same for all observers, and the principle of the constancy of the speed of light, which states that the speed of light is the same for all observers regardless of their relative motion.
How does relativity affect our perception of time and space?
Relativity suggests that time and space are relative concepts and can be affected by the presence of gravity. This means that time can pass at different rates for different observers, and distances can appear to be different depending on the observer's frame of reference.
Can you give an example of how relativity has been proven?
One of the most famous examples of relativity being proven is the theory of general relativity, which was confirmed by observations of the bending of light around massive objects such as stars. This was demonstrated during a solar eclipse in 1919, when the position of stars appeared to shift due to the gravitational pull of the sun.
