Relativity, force, acceleration, momentum
In summary, the conversation includes a discussion about the relativistic factor q, and the equations F=q*m0*a and E=m*c^2. There is also mention of dE=dm*c^2 and dL=F*dx, and the relationship F*dx=dm*c^2. Finally, there is a suggestion to study "Introduction to special relativity" by Robert Resnick and a request for someone to explain where the mistake is in the computations.
DonnieD
let q=relativistic factor
then F=q*m0*a (where m0 is rest mass and a=acceleration)
if E=m*c^2 =>dE=dm*c^2 (i'm not sure about this)
and dL=F*dx (is the infinitesimal work completed by an external strenght F on the system)
F*dx=dm*c^2 =>
q*m0*a*dx=dm*c^2 => dm/m0=(q*a/c^2)*dx
m'(x)=q*m0*a(x)/c^2 ==> F=m'(x)*c^2 .
a=m'(x)*(c^2/(q*m0))
is right?
No,I suggest you to study "Introduction to special relativity"
Robert Resnick.
I can provide you the detailed computations,if you want.
someone can explain easy, where's the mistake?
Well, this is wrong for a start
I suggest you read http://math.ucr.edu/home/baez/physics/Relativity/SR/mass.html" , specifically the addendum at the end, to begin with.
F is defined as dp/dt and p = qm0v. But v is contained in the factor q so when you derive p you actually obtain:
F = qm0a + q^3(m0/c^2)(v°a)v
where ° means scalar product.
Just a light correction on lightarrow's post (and to make things a little easier to read);
[tex]\vec{F} = \gamma m_{0}\vec{a} + \gamma^{3}m_{0}\frac{\vec{v}\cdot\vec{a}}{c^2}\vec{v}[/tex]
Edit: Ahh lightarrow's on the ball today :wink:
FAQ: Relativity, force, acceleration, momentum
What is the theory of relativity and who developed it?
The theory of relativity is a scientific theory developed by Albert Einstein in the early 20th century. It is a theory that explains how gravity works and how objects behave in space and time.
What is the difference between Newton's laws of motion and Einstein's theory of relativity?
Newton's laws of motion describe the behavior of objects in a non-accelerating frame of reference, while Einstein's theory of relativity describes the behavior of objects in all frames of reference, including those that are accelerating.
How does force affect an object's acceleration?
Force is directly proportional to an object's acceleration, meaning that the greater the force applied to an object, the greater its acceleration will be. This relationship is described by Newton's second law of motion.
What is the difference between force and momentum?
Force is a measure of the influence that causes an object to accelerate, while momentum is a measure of the object's motion. In other words, force causes an object to accelerate, whereas momentum is the result of an object's acceleration.
How does an object's mass affect its momentum?
An object's mass directly affects its momentum, as momentum is equal to an object's mass multiplied by its velocity. This means that the greater an object's mass, the greater its momentum will be at a given velocity.
