Relativity, how it affects observation.
In summary, the conversation discusses problems related to relativity, specifically regarding the length, time, and mass of a spaceship and astronaut at different speeds. The general answers to each problem are 65m for the length of the spaceship from the astronaut's perspective and 39m from the observer's perspective, 7.447818 years for the time it takes to reach Proxima Centauri from the astronaut's perspective and 8.6 years from the observer's perspective, and 75 kg for the astronaut's mass and approximately 113 kg for the observer's mass. Relevant equations that may be needed include the equation for length contraction, time dilation, and the equation for calculating mass at relativistic speeds.
chewtoy929
I'm having a bit of trouble understanding relativity, and would like some help with the following problems:
1. A spaceship passes a stationary observer at a speed that is 80% the speed of light. At rest, this ship is 65m long. What does the observer say about the length of the spaceship? How does this length compare to that
measured by an astronaut inside the spaceship?
2. A spaceship capable of flying 50% of the speed of light, travels from Earth to Proxima Centauri, the star closest to the Earth other than our own Sun at a distance of 4.3 light years. What does an astronaut inside the spaceship have to say about the length of time it takes to reach Proxima Centauri? How does this time compare to that measured by an observer stationed on Earth?
3. On Earth an astronaut has a mass of 75 kg. If they are in a spaceship that is flying at 75% of the speed of light, then what does a stationary observer have to say about the astronaut's mass? What does the astronaut have to say about their own mass?
Why don't you start out with the concepts behind each problem; what will be the general answer to each. Then, what relevant equations do you think you might need?
1= 65m from astronaut, 39 observer
2= 7.447818 astronaut, 8.6 observer
3= 75 kg astronaut, ~113 kg observer
Looks good!
It sounded like you were having trouble with some of the concepts, however. Are they clear now?
1. According to the theory of relativity, the observer will see the spaceship as shorter than its actual length. This is because as an object approaches the speed of light, its length appears to contract in the direction of motion. Therefore, the observer will measure the length of the spaceship to be less than 65m. On the other hand, the astronaut inside the spaceship will measure the length of the spaceship to be 65m, as they are at rest relative to the spaceship.
2. According to relativity, the astronaut inside the spaceship will experience time dilation, meaning that time will appear to pass slower for them compared to the observer on Earth. Therefore, the astronaut will measure the time it takes to reach Proxima Centauri to be shorter than 4.3 years. However, the observer on Earth will measure the time to be 4.3 years.
3. According to the theory of relativity, the observer will measure the astronaut's mass to be greater than 75 kg. This is because as an object approaches the speed of light, its mass increases. On the other hand, the astronaut will measure their own mass to be 75 kg, as they are at rest relative to themselves. This is known as the principle of equivalence, which states that all observers, regardless of their state of motion, will measure the same physical laws.
Related to Relativity, how it affects observation.
1. What is the theory of relativity?
The theory of relativity, developed by Albert Einstein, is a set of two theories: special relativity and general relativity. It explains how the laws of physics are the same for all observers in uniform motion and how gravity affects the fabric of space and time.
2. How does relativity affect our observations?
Relativity affects our observations by showing us that time and space are relative and can be distorted by gravity. It also explains the phenomenon of length contraction and time dilation, which occur at high speeds and in strong gravitational fields.
3. What evidence supports the theory of relativity?
There is a significant amount of evidence that supports the theory of relativity. For example, the observation of the bending of starlight by the sun's gravity during a solar eclipse, the confirmation of time dilation by atomic clocks on high-speed airplanes, and the precise calculations of the perihelion shift of Mercury's orbit all support the theory.
4. How does special relativity differ from general relativity?
Special relativity deals with the laws of physics in uniform motion and does not take into account gravity. General relativity, on the other hand, includes gravity and explains how it affects the structure of space and time.
5. Can the theory of relativity be proven wrong?
As with any scientific theory, the theory of relativity can be modified or disproven with new evidence or observations. However, so far, it has withstood numerous tests and is considered one of the most well-supported theories in physics.
