Relativity of spring constant
In summary, the conversation discusses the concept of the spring constant and its relation to the motion of charges held apart by a compressed spring. It is observed that the Lorentz force on the charges is reduced in a moving frame, leading to the question of whether the spring constant is affected by the spring's motion relative to an inertial reference frame. Previous studies have shown that the spring constant and modulus of elasticity may change for springs parallel and transverse to the motion, but further research is needed.
GRDixon
249
Relativity of spring "constant"
Let equal-magnitude, oppositely signed charges be at rest at the Origin and on the y-axis of IRF K. They are held apart by a compressed spring. The force exerted by the spring on either charge is equal and oppositely directed to the electrostatic force.
Viewed from IRF K’, which moves in the positive x-direction of K at speed v, the charges and the spring move in the –x’ direction at common speed v. But according to the general field transformations the Lorentz force on either charge in K’ is less than it is in K by a factor (1-v^2/c^2)^(1/2). Is the spring constant actually a function of the spring’s motion relative to an IRF? And if so, what is the general rule for arbitrary spring orientations in frame K’?
If I can understand you correctly, as soon as the spring is released, the charges start to move along the y-axis of IRF K. But the point is that in order to have a relativistic motion, the trajectory of motion in both K and K' must in the the same direction (as is assumed here, the direction of x-axis), while in this example, K' moves in the positive x-direction of K, so it is impossible for an observer in K' to measure any relativistic thing in K.
AB
This may be helpful: Grøn, Covariant formulation of Hooke's law, Am. J. Phys. 49, 28-30 ( 1981 )
It is not going to be helpful that much, since its framework is surely GR and in the SR, unfortunately the matter tensor vanishes so no contribution of the spring constant exists anymore. The same topic can be found in a very better and glib language http://arxiv.org/pdf/gr-qc/0005099".
AB
FAQ: Relativity of spring constant
What is the spring constant?
The spring constant, also known as the force constant, is a measure of the stiffness of a spring. It is represented by the symbol k and is expressed in units of Newtons per meter (N/m).
How is the spring constant determined?
The spring constant can be determined by measuring the force applied to a spring and the resulting displacement. The spring constant is equal to the applied force divided by the displacement.
Is the spring constant a constant value?
No, the spring constant can vary depending on the material, shape, and temperature of the spring. It is a property of the spring and remains constant as long as these factors do not change.
How does the spring constant relate to Hooke's Law?
Hooke's Law states that the force exerted by a spring is directly proportional to the displacement of the spring from its equilibrium position. The spring constant is the proportionality constant in this relationship, and it determines the strength of the force exerted by the spring.
Is the spring constant affected by the mass of the object attached to the spring?
Yes, the spring constant is affected by the mass of the object attached to the spring. Heavier objects will cause the spring to stretch more, resulting in a larger displacement and a larger spring constant.
