Relativity: Proper time and length
In summary, proper time is the time interval observed in a reference frame where the two events occur in the same place, while proper length is the length measured in a reference frame where the object is at rest. The formulas used to calculate proper time and length can be found in textbooks such as Halliday/Resnick/Walker. Additionally, the relative speed of a clock running at half the rate of a clock at rest is equal to half the speed of the clock at rest. Similarly, the relative speed of a meter stick observed to shrink to 0.25 m is equal to 0.25 times the speed of the meter stick at rest. In the case of two spaceships approaching each other at a relative speed of 0.
sydboydell31
(a) Write down the definition of proper time and explain how to use the appropriate formula with an example.
(b) Write down the definition of proper length and explain how to use the appropriate formula with an example.
(c) At what relative speed does a clock move if it runs at a rate that is one-half the rate of a clock at rest?
(d) At what relative speed does a meter stick move if its length is observed to shrink to 0.25 m?
(e) Two spaceships approach each other, each moving with the same speed as measured by a stationary observer on the Earth. Their relative speed is 0.70c. Determine the velocities of each spaceship as measured by the stationary observer on Earth.
i know that proper time/length means it's the time of an observer's own measurement, but how would you describe that using formulas?
Sorry but i really couldn't find any website/books with a good explanation. Thanks guys
All you'll have to understand is that the term is "proper time-interval" not "proper time".
the proper time interval is the time interval observed in a reference frame in which the two events that determines the time interval occurs in the same place. the proper length is the length measured in a reference frame with respect to which, the object whose length is to be measured, is at rest.
If you still don't understand, look up in Halliday/Resnick/Walker. it's helpful.
FAQ: Relativity: Proper time and length
What is the concept of proper time in relativity?
The concept of proper time in relativity refers to the time experienced by an observer who is moving along with a clock. It is the time measured by a clock in its own frame of reference, and it is always the shortest possible time interval between two events in the same location.
How does relativity affect the measurement of time and length?
Relativity states that time and length are relative and can change depending on the observer's frame of reference. This means that the measurement of time and length can vary for different observers, and what is considered as a certain amount of time or length for one observer may not be the same for another observer.
Can an object experience time dilation and length contraction simultaneously?
Yes, an object can experience both time dilation and length contraction at the same time. This occurs when the object is moving at high speeds relative to an observer. As the object moves faster, time appears to slow down for the observer, and its length appears to contract in the direction of motion.
How does proper time and length relate to the theory of special relativity?
Proper time and length are fundamental concepts in the theory of special relativity. They are used to explain how time and space are affected by an observer's relative motion and the speed of light. They are also crucial in understanding the concept of time dilation and length contraction.
Is there a limit to how much time can be dilated or how much length can be contracted?
According to the theory of special relativity, there is no limit to how much time can be dilated or how much length can be contracted. As an object's velocity approaches the speed of light, time dilation and length contraction become more significant. However, the speed of light is considered to be the ultimate speed limit, and it cannot be exceeded by any object.
