Relativity Question: Airliner -- Light & ball movement
In summary, the velocity of the ball thrown from the plane towards the back of the plane from the Earth's frame of reference would be 280 m/s [forward] and the light would remain at a constant 3.0 x 10^8 m/s. Time dilation would still occur if measured from the Earth's frame of reference, but would be negligible in this scenario. If measured from inside the plane, there would be no time dilation.
Jaimie
35
Imagine that you are flying on an airliner on a long flight to Europe at a constant speed of 300 m/s
a) you throw a ball towards the back of the plane at 20 m/s. You then shine a beam of light towards the back of the plane. How will these two things i) the ball and ii) the light-- appear to move from the Earth's frame of reference
b) would you expect your watch to be affected by time dilation?
Δtm = Δts/√(1-v2/c2)
V(be)= -V(bp) + V(pe)
a) i) b= ball; e= earth; p= plane
∴ V(be)= -V(bp) + V(pe)= -20 m/s + 300 m/s = 280 m/s [forward].
ii) The light will remain at a constant 3.0 x 10^8 m/s from the earth’s frame of reference.
Velocity is dependent on its’ inertial reference frame and its’ direction of travel. From the Earth frame of reference, both the direction of the thrown ball and the direction of the airplane travel determines its’ velocity as per vector subtraction. If we were to look at the ball moving from a different inertial frame of reference (i.e. from the plane), the ball would experience only the velocity of 20m/s [backwards] and if the ball was thrown forward, the velocity of the ball would be 20 m/s + 300 m/s= 320 m/s [forward]. Light on the other hand is independent of its’ reference frame and shows a constancy of 3.0 x 10^8 m/s relative to all inertial reference frames (special relativity postulate 2), regardless of which direction it is travelling. If we were to measure the speed of light from inside the plane or if it were traveling back or forwards, its’ velocity would still be 3.0 x 10^ 8 m/s.
b) If time was being measured from the earth’s frame of reference, time dilation would still occur relative to the time experienced from the airplane. However, because the plane is not traveling at a speed close enough to the speed of light, increasing the time difference between both reference frames, time difference and time dilation would be negligible. As such, my watch would not be accurate enough to pick up the time difference. If time was measured from the inside the plane, my watch would only experience normal time and would not experience time dilation at all.
Could someone review my answers and tell me if I am understanding these concepts?
Thank you for your time!
As this is a relativity question, I would use the relativistic formula and sufficient precision to see the difference to the nonrelativistic case.
Sure.
Right. There are watches precise enough to note the time dilation, however.
Hi mfb,
Re a) i & ii) :
At this point we weren't taught about inertial/non-inertial frames of reference, time dilation and simultaneity, with no other equations other than that for time dilation. So based on this info, are both these answers correct? Thank you!
(I'm curious though, which equation(s) were you referring to?)
Should be fine.
Relativistic velocity addition.
You need a modified formula in relativity - this becomes more easy to see if your ball moves with (speed of light minus 10m/s) forwards in the plane, for example. The classical addition would give a speed above the speed of light, which is obviously wrong. The correct relativistic formula also allows to plug in the speed of light, and the result is the speed of light again as expected.
*Correction*
"At this point we were taught only about inertial/non-inertial frames of reference, time dilation and simultaneity..." Had to fix that in my last post.
So when you're saying "should be fine", you're saying that based on what I learned, my answer to part a i) is correct? I just wanted to clarify.
Interesting. I wish we would have learned about this as this makes more sense based on your explanation.
Thank you for your help!
I'm not in your course, but if you did not learn relativistic velocity addition yet, it is fine.
Great! Thank you for your help.
Related to Relativity Question: Airliner -- Light & ball movement
1. How does relativity explain the movement of light in an airliner?
According to Einstein's theory of relativity, the speed of light is constant in all frames of reference. This means that the speed of light remains the same regardless of the speed of the observer or the source of light. Therefore, the movement of light in an airliner will appear the same to both a passenger on the plane and an observer on the ground.
2. Does the speed of the airliner affect the speed of light inside the plane?
No, the speed of the airliner has no effect on the speed of light inside the plane. As stated in the previous answer, the speed of light is constant in all frames of reference, so it will remain the same regardless of the speed of the observer or the source of light.
3. How does a ball thrown inside an airliner behave according to relativity?
The movement of the ball will appear the same to both a passenger on the plane and an observer on the ground. This is because the ball is moving at the same speed as the plane, so it is in the same inertial frame of reference. However, if the plane were to suddenly change its speed or direction, the ball would appear to move differently to the observer on the ground due to the effects of relativity.
4. Can relativity explain why objects appear to weigh more in a moving airliner?
Yes, according to Einstein's theory of relativity, objects appear to weigh more when they are in motion due to the effects of time dilation. The faster an object moves, the slower time moves for the object, making it appear to have more mass to an outside observer. This is known as the "relativistic mass" of an object.
5. How does relativity affect the experience of time for passengers on an airliner?
Relativity states that time is relative and can change based on the speed and gravity of an object. Therefore, passengers on an airliner will experience time differently than someone on the ground. This is because the plane is moving at a high speed, causing time to move slower for the passengers compared to someone on the ground. This effect is known as time dilation and has been proven through various experiments, including using atomic clocks on airplanes.
