Jon.G
- 45
Relativity -- Sphere flattening due to relativistic speed
Gum balls are spherical, and about 1.5 cm in diameter. Smarties are circular in one cross
section, with the same diameter, but perpendicular to this circular cross section, they
are flattened, with the smallest diameter being half the largest diameter. The mass of a
smartie is 15 g.
a) How fast does a gum ball have to be moving with respect to an observer for this
observer to mistake it for a smartie? Give your answer as a fraction of the speed of
light.
(b) Purple and red smarties reflect incident sunlight predominantly at wavelengths of
380 nm and 750 nm respectively. If one colour of smartie is moving towards you,
it can look like the other colour when it is stationary. Which smartie has to be
moving, and at what fraction of the speed of light does it have to travel?
(c) If it were possible to convert [itex] 10^{-6} [/itex] of the mass of the smartie into energy, for how long coul the released energy power a 100MW power station?
(d)If the energy released as described in part 2(c) was converted instead into kinetic
energy of the smartie, by how much would the smartie final velocity differ from
that of light? Give your answer in m/s
(a) - Erm...![Cry :cry: :cry:](/styles/physicsforums/xenforo/smilies/cry.png)
(b) - Not much better. I know that it is the red smartie that must be moving towards us.
I know for non-relativistic doppler shift [itex] \frac{\Delta\lambda}{\lambda_{emitted}}=\frac{v}{c} [/itex]
and for relativistic doppler shift I know [itex]\frac{\lambda_{observed}}{\lambda_{emited}}=\sqrt{\frac{1+\beta}{1-\beta}} where \beta=\frac{v}{c} [/itex]
Do I simply rearrange this formula? Doing this I got [itex] v=\frac{59}{100}c[/itex]
(c)
[itex] m=0.015*10^{-6}[/itex]
[itex] E=mc^{2}; c=3*10^{8} [/itex]
[itex] so E=1350MJ [/itex]
[itex] Power = \frac{Energy}{time} ; so time=\frac{Energy}{Power}[/itex]
[itex] time = 13.5 seconds [/itex]
I'm not too confident with this, it seems a bit too simple :/ , however it is only 2 marks
(d)Again, I think it would be far too simple to use [itex] E=\frac{1}{2}mv^{2} [/itex] with E=1350 MJ
Thanks
smartie is 15 g.
light.
(a) - Erm...
(c)
Thanks
