Relavtivity Question - Unit Needed
  • Thread starter TheController
  • Tags
    Unit
In summary, the problem at hand is determining the unit to use for a calculated velocity. Relevant information includes the relative time (T) and stationary time (To), both given in years, and the unknown velocity (U). The solution involves using the speed of light (c) as a unit or stating the value of c (3e8m/s) to get the answer in meters per second.
TheController
1. The problem
I need to know what unit I would use for my calculated velocity?
2. Relevant Information
T (Relative Time) = 9 years
To (Stationary Time) = 2 years
U (Velocity) = ?
Solution?
What unit would I use for the velocity received?
TheController said:
1. The problem
U (Velocity) = ?
Solution?
The factor relating T to To will contain the ratio v/c, so you can use the speed of light as your unit, or you can say c = 3e8m/s and get the answer in m/s.
Etc.
FAQ: Relavtivity Question - Unit Needed
What is the concept of relativity?
The concept of relativity is a fundamental principle in physics that states that the laws of physics are the same for all observers, regardless of their relative motion. This means that there is no preferred frame of reference in the universe.
What is the difference between special and general relativity?
Special relativity deals with the laws of physics in inertial frames of reference, while general relativity deals with the laws of physics in non-inertial frames of reference, including those with gravitational fields.
What is the unit of measurement used in relativity?
The unit of measurement used in relativity is the same as in other branches of physics - the SI (International System of Units). Some common units used in relativity include meters, seconds, kilograms, and joules.
How does relativity affect our daily lives?
Relativity has a wide range of applications in our daily lives, including GPS systems, satellite communication, and nuclear energy. It also plays a crucial role in understanding the behavior of the universe on a large scale.
Is relativity a proven theory?
Yes, relativity has been extensively tested and confirmed through various experiments and observations. It is considered one of the most well-established and successful theories in physics.
