Relevant highest order harmonics in power systems
In summary: When reading about THD literally everyone was ignoring the even harmonics, i read it's because the half-cycle symmetry and it was mentioned " which is very common in power applications", so my question is there any common application where there is half cycle symmetry ( i am not speaking of dc offset which can easily be removed) i couldn't think of any tbh.There is no one answer to this question. It would depend on the specific application.
Axe199
48
i am learning about harmonic analyzers and i have a couple of questions concerning them that need some sort of practical experience to answer them ( and i have none :) ) :
1-can harmonic analyzer analyze up to any harmonic? or is there a maximum ? if there is no maximum what's the highest order harmonic that is relevant to us in power systems ? i read somewhere online that when calculating THD they normally include up to the 15th -17th harmonic, and a friend told me that no one cares about what's beyond the 55th or so because these high frequencies are attenuated by the inductance of transformers or motors, so i need a practical opinion on this .
2- when i was reading about THD literally everyone was ignoring the even harmonics, i read it's because the half-cycle symmetry and it was mentioned " which is very common in power applications", so my question is there any common application where there is half cycle symmetry ( i am not speaking of dc offset which can easily be removed) i couldn't think of any tbh.
3- how do harmonic analyzers deal with different power quality problems that can affect their readings like frequency and voltage fluctuations? does the input has to be a steady periodic wave to get accurate answers?
Are you asking about harmonic distortion from the AC Mains power source, or from equipment that is hooked to the AC Mains?
If the latter, one applicable standard is EN 61000-3-2:
https://en.wikipedia.org/wiki/IEC_61000-3-2
It does look like they are not checking the even harmonics of the power waveform. I end up having to test to this standard for some of the products we design because of Power Factor quality issues with some simple switching power supplies. You pretty much have to use a Power Factor Corrected switching power supply to pass this Harmonics test.
so according to this standard they are checking and including in the THD up to the 40th harmonic
i am asking in general , either it's the mains voltage or inverter ouput or line current to some motor
Related to Relevant highest order harmonics in power systems
1. What are relevant highest order harmonics in power systems?
Relevant highest order harmonics in power systems refer to the harmonics that have the highest magnitude and impact on the power quality of a system. These harmonics are typically the odd-order harmonics, such as 3rd, 5th, 7th, etc.
2. How do these harmonics affect power systems?
These harmonics can cause voltage and current distortions, which can lead to various issues such as equipment damage, power losses, and decreased power quality. They can also create resonance conditions and affect the stability of the system.
3. What are the sources of these harmonics in power systems?
The main sources of these harmonics are non-linear loads, such as electronic devices, power converters, and variable speed drives. These loads draw non-sinusoidal currents, which result in the production of harmonics in the system.
4. How can we mitigate the effects of relevant highest order harmonics?
There are various methods for mitigating the effects of these harmonics, such as using harmonic filters, transformers with reduced leakage reactance, and active power filters. Proper system design and maintenance can also help reduce the impact of these harmonics.
5. What are the standards and regulations for controlling relevant highest order harmonics in power systems?
Different countries and regions have their own standards and regulations for controlling harmonics in power systems. In the United States, the IEEE 519 standard provides guidelines for acceptable levels of harmonics in power systems. In Europe, the IEC 61000-2-4 standard sets limits for harmonic emissions in industrial environments.
  • Electrical Engineering
9K
