Remnant Magnetisation varying with input amplitude
In summary: So if you know the linear response function, you can get the response to any input. ( This is basically a Green's function construction).In summary, in a lab experiment, the remnant magnetisation of a hysteresis loop was measured for different core materials. The results showed that the permalloy sample exhibited a sinusoidal relationship between the remnant magnetisation and the input amplitude of the sinusoidal wave. However, this relationship did not occur for silver steel or mild steel cores. This suggests that the permalloy sample has a linear response to the applied magnetic field, while the other materials behave more like permanent magnets.
Cortizza
Thread moved from the techniccal forums, so no Homework Help Template is shown
In a lab we had to measure the remnant magnetisation of a hysteresis loop with a permalloy core. The amplitude of the input sinusoidal wave was varied and the resulting remnant magnetisation measured. This was then plotted resulting in the remnant magnetisation varying sinusoidal with the input amplitude. When the core was changed to silver steel or mild steel the sinusoidal relationship no longer occured.
Why did the remnance vary sinusoidally with amplitude only for the permalloy sample?
Welcome to the PF.
Have you found datasheets or other technical information on those core materials? You should be able to find Google Images showing the hysteresis curves as you increase the amplitude of the excitation.
I'm not sure of your definition of "remnant magnetization", but it sounds like you were basically measuring ## \chi_m(\omega) ## , where ## \vec{M}(\omega)=\chi_m(\omega) \vec{H}(\omega) ##. The vector ## \vec{H}(\omega) ## is the applied magnetic field at frequency ## \omega ## from the solenoid. And ## \chi_m(\omega) ## is the magnetic susceptibility=it is in general frequency dependent. ( Presumably you measured ## \chi_m(\omega) ## for only one specific frequency, which is ok).## \\ ## In the first case, you must have had a material where the response was linear, so that ## \chi_m(\omega) ## is a constant for a given frequency (sometimes a complex one, so that a phase delay can be included in the response). ## \\ ## For the other materials, it is likely they are more like a permanent magnet, where no such linear response occurs. You simply can not write a linear equation for these materials relating ## \vec{M}(\omega) ## to ## \vec{H}(\omega) ##. ## \\ ## There is one additional item that may be worth including if you have any mathematical background in linear response theory: The equation ## \vec{M}(t)=\int\limits_{- \infty}^{t} \chi_m(t-t') \vec{H}(t') \, dt' ## is applicable if the system responds linearly. The equation ## \vec{M}(\omega)=\chi_m(\omega) \vec{H}(\omega) ## follows from the convolution theorem, where in this last equation, these are all Fourier transforms of the quantities of the integral equation.
Related to Remnant Magnetisation varying with input amplitude
What is remnant magnetisation?
Remnant magnetisation is the residual magnetic field that remains in a material after an external magnetic field is removed.
How does remnant magnetisation vary with input amplitude?
The strength of remnant magnetisation is directly proportional to the input amplitude of the magnetic field. This means that the higher the input amplitude, the stronger the remnant magnetisation will be.
What factors affect the variation of remnant magnetisation with input amplitude?
The main factors that affect the variation of remnant magnetisation with input amplitude include the type of material, the strength and direction of the external magnetic field, and the temperature of the material.
Can remnant magnetisation be reversed?
Yes, remnant magnetisation can be reversed by applying an external magnetic field in the opposite direction. This process is known as demagnetisation.
How is remnant magnetisation used in scientific research?
Remnant magnetisation is often used in paleomagnetism studies to determine the Earth's magnetic field strength and direction in the past. It is also used in material science to measure the magnetic properties of different materials and in magnetic storage devices such as hard drives.
11K
  • Mechanical Engineering
  • Electrical Engineering
  • Beyond the Standard Models
