Remote Control Car Specifications
In summary: It has a stall torque of 12 N.e) In summary, to achieve the desired speed, the car's motor would require a power output of 10.5 watts.
trynalearn
[/B]
You are building a remote control car. The car has 50 mm tire diameter, and you want the car to travel on level ground at a speed of 9 mph. You need to select a single motor and gear head for the project. Provide hand written calculations and answers to the following questions. Note: be sure to write out all units in your calculations, and perform any necessary unit conversations.a) To travel at the desired speed, what is the required angular velocity of the tires (in rpm and rad/s)?
b) Assume an idealized system (no losses due to friction, no tire slippage, etc.), and that the car requires a constant force of 12 N to move across this particular ground condition. To achieve the desired speed what would be the minimum power (in watts) required for the car’s motor?
c) Select a DC motor (from an online supplier, e.g., Maxon) that uses ≤24 V nominal voltage and has at least 10% more power output than what you calculated in part b. Provide the part number and also download and attach a copy of the motor’s specification sheet.
d) Assume you wanted the motor to operate near peak efficiency (at about 25% of the stall torque), what gear reduction ratio would be needed to obtain the desired torque output at the tires (note: calculate the required torque first), again assuming an ideal lossless system?
e) Find a gear head (gearbox) with appropriate reduction ratio (from an online supplier). Provide the part number and also download and attach a copy of the specification sheet. Try to find one which matches the motor shaft size.
f) Check if the angular velocity output from the gear is still larger than the angular velocity required (which you calculated in part a).
g) In this exercise we assumed an idealized system to select a motor and gear head. But in reality there are always some mechanical losses, and therefore power transmission will not be 100% efficient. Look on the data sheet for the gear head you selected and report the efficiency (often reported as maximum efficiency) of the gear head.
They are listed below.
a) v = rw, Solve for w. Is this right?
b) P1 = Fv, Solve for P1. Is this right?
c) P1=VI, Solve for I
d) To=rF, Solve for To (torque output). What is stall torque? Is it the torque output? If not, how do I get it?
G=win/wout How do I find win?
e)
f)
g)
Does the number of tires of the remote control car matter? Let's say there are 4 tires. How does it relate with the calculations?
Stall torque is the peak torque of a typical DC motor at 0 rpm. The torque decreases linearly as rpm increases until the torque goes to 0 at the motor's maximum "unloaded" rpm. So peak efficiency should occur at about 75% maximum rpm. (Peak power output occurs at about 50% maximum rpm). You'll also need to know the motor constants like Kv, maximum rpm, ... . Wiki article:
http://en.wikipedia.org/wiki/Motor_constants
Yes (if correct units are used).
You forgot to add 10%. Which motor did you select?
See the data sheet for the motor you selected.
Related to Remote Control Car Specifications
1. What is the maximum speed of a remote control car?
The maximum speed of a remote control car varies depending on the model and brand. Generally, most remote control cars have a maximum speed of 10-15 miles per hour.
2. What is the range of a remote control car?
The range of a remote control car refers to the distance it can travel from the remote controller. Most remote control cars have a range of 100-200 feet. However, this can also vary depending on the model and brand.
3. What type of batteries does a remote control car use?
Most remote control cars use rechargeable batteries, such as NiMH or LiPo batteries. However, some models may also use standard AA or AAA batteries. It is important to check the specifications of your specific remote control car to determine the type of batteries it requires.
4. What is the scale size of a remote control car?
The scale size of a remote control car refers to its size in comparison to a real-life car. The most common scale sizes for remote control cars are 1:10, 1:12, and 1:18, with 1:10 being the most popular.
5. Can remote control cars be used on any terrain?
While some remote control cars are designed specifically for certain terrains, such as off-road or on-road, many models are versatile and can be used on a variety of terrains. It is important to check the specifications of your specific remote control car to see what terrains it is suitable for.
  • Mechanical Engineering
