Renomalizabilty and triple/quadruple vertices
  • A
  • Thread starter klauskl
  • Tags
    Lagrangian
In summary, "Renormalizability and triple/quadruple vertices" discusses the conditions under which quantum field theories can be renormalized, focusing on the implications of having triple and quadruple vertex interactions. It highlights how these vertices affect the behavior of particle interactions and the necessity of introducing counterterms to handle divergences. The text emphasizes the importance of renormalizable theories in ensuring predictive power and consistency in physical models, particularly in high-energy physics.
klauskl
I read that a Lagrangian is renormalizable if it contains only triple and quadruple vertices, or at most four powers of the fields.
Where can I read more about the precise mathematical conditions?
This depends on the dimensionality of the fields. A 4-fermion interaction (such as the one in the Fermi theory of weak interactions) is not renormalizable. This should be covered in any QFT textbook. Peskin & Schröder is pretty standard, but there are of course others too.
Likes klauskl
FAQ: Renomalizabilty and triple/quadruple vertices
What is renormalizability in quantum field theory?
Renormalizability is a property of a quantum field theory that allows for the absorption of infinities arising from loop diagrams into a finite number of redefined (renormalized) parameters, such as masses and coupling constants. A renormalizable theory ensures that predictions remain finite and physically meaningful after renormalization.
Why are triple and quadruple vertices important in quantum field theory?
Triple and quadruple vertices correspond to interaction terms involving three or four fields, respectively, in the Lagrangian of a quantum field theory. These vertices are crucial because they determine the types of interactions that particles can undergo, influence the structure of Feynman diagrams, and affect the renormalizability of the theory.
How do triple and quadruple vertices affect renormalizability?
Triple and quadruple vertices can affect the renormalizability of a theory by introducing interaction terms that may lead to divergences in loop diagrams. The power-counting of these vertices helps determine whether the divergences can be absorbed into a finite number of renormalized parameters. For a theory to be renormalizable, the vertices must lead to divergences that can be systematically controlled.
What is the significance of power-counting in determining renormalizability?
Power-counting is a method used to analyze the degree of divergence of Feynman diagrams based on the dimensions of the fields and coupling constants involved in the vertices. By examining the superficial degree of divergence, power-counting helps determine whether the infinities arising in the theory can be renormalized. A theory is renormalizable if the divergences can be absorbed by a finite number of counterterms.
Can non-renormalizable theories still be useful in physics?
Yes, non-renormalizable theories can still be useful as effective field theories, which are valid at a certain energy scale. While they may not be renormalizable in the traditional sense, they can provide accurate descriptions of physical phenomena within their domain of applicability. At higher energies, these theories are expected to be replaced by a more fundamental, renormalizable theory.
