A Renormalization with hard cutoff of a loop diagram with single vertex
theittsco
TL;DR Summary
Confusion on how to renormalize a loop diagram with only a single vertex. Feynman parameters don't work.
Trying to solve for the loop contribution when renormalizing a one loop ##\frac{\lambda}{4!}\phi^4## diagram with two external lines in ##d=4## dimensions. After writing down the Feynman rule I see that:
$$\frac{(-i\lambda)}{2}\int d^4q \frac{i}{q^2-m_{\phi}^2+i\epsilon} $$
But I see no way to convert this to Feynman parameters like in ##1/AB##. When I Wick rotate I get:
$$\frac{(\lambda)}{2}\int dq_E \frac{q_E^3}{q_E^2-m_{\phi}^2} $$
Which when integrated from ##0,\Lambda## (a hard cut off) via the great Mathematica yields:
$$\lambda/2 (1/2)(\Lambda^2-m^2\log(-m^2)+m^2\log(\Lambda^2-m^2))$$
My renormalization conditions are ##\Pi(m^2)=\Pi'(m^2)=0##, so when solving for counter terms:
$$i\Pi(p^2) = \lambda/2 (1/2)(\Lambda^2-m^2\log(-m^2)+m^2\log(\Lambda^2-m^2)) + i(\delta_Zp^2-\delta_m)$$
my counter terms still end up with ##\Lambda## dependence. So I messed up somewhere but I can't figure out where. Help please!
Your counter terms should absolutely depend on the cut-off, that's how they cancel the divergences. There's no momentum dependence so ##\delta_Z = 0## and ##\delta_m## cancels out everything. Also I'm pretty sure you made a mistake when you did your wick-rotation, the sign in the denominator should be positive.
The whole idea behind renormalized perturbation theory is that you deform your theory with some parameter ##\Lambda## that makes the observables finite, then you ascribe ##\Lambda##-dependence to your constants which are selected to cancel the infinites and satisfy the renormalization conditions.
Likes vanhees71 and theittsco
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
