Renormalized vertex always a log?
In summary, the reason that one-loop corrections to vertex functions tend to be logarithmic is due to the nature of the vertex and the theory it is part of. This is a result of renormalization, where the first few divergent terms are subtracted off, leaving a Taylor series that is dominated by a logarithmic term. This is preferred over a quadratic divergence and is explained by Weinberg's theorem. Exceptions to this tend to occur with theories involving dimensionless coupling constants.
geoduck
258
Is there a reason that one-loop corrections to vertex functions seem to always be logarithmic?
If you write the vertex as a Taylor series in the external momenta, then the first couple of terms (say the constant and linear terms) diverge, but these divergence gets subtracted off, so you now have a Taylor series minus the first couple of terms, and this Taylor series is a log?
With some exceptions (e.g., the 4-photon vertex), the one-loop divergence is given by the usual power-counting arguments, and depends on the nature of the vertex, and the theory that it's part of.
That said, we are often interested in theories with dimensionless coupling constants, and (again probably with some exceptions, though none come to mind at the moment) then the one-loop vertex correction (to a vertex corresponding to a dimensionless coupling) is indeed logarithmic, by power-counting arguments.
that is the result of renormalization,it is better to have a logarithmic divergence compared to quadratic one.
FAQ: Renormalized vertex always a log?
1. What is a renormalized vertex?
A renormalized vertex is a mathematical concept used in quantum field theory to describe the interaction between particles. It represents the strength of the interaction between two particles, and is often calculated through a process called renormalization.
2. Why is the renormalized vertex important?
The renormalized vertex is important because it allows us to accurately describe and calculate the interactions between particles in quantum field theory. Without it, our calculations would be plagued with infinities and inconsistencies.
3. What does it mean for the renormalized vertex to always be a log?
When we calculate the renormalized vertex, it often involves taking the logarithm of certain parameters. This is due to the nature of the renormalization process and the mathematical techniques used. As a result, the renormalized vertex will always involve a logarithm in its expression.
4. How is the renormalized vertex different from the bare vertex?
The bare vertex is the initial value of the interaction strength between particles, and it is often plagued with infinities. The renormalized vertex, on the other hand, is a finite and well-defined quantity that takes into account the effects of virtual particles. It is a more accurate representation of the true interaction between particles.
5. Can the renormalized vertex be negative?
Yes, the renormalized vertex can be negative. This means that the interaction between particles is attractive, as opposed to being repulsive when the renormalized vertex is positive. The sign of the renormalized vertex depends on the type of particles and the nature of their interaction.
