Repairing the Chesapeake Bay Bridge
  • Thread starter tasp77
  • Tags
    Bridge
In summary, the damaged portions of the Chesapeake Bay Bridge were fixed by driving new pilings into the same location as the sheared off pilings.
tasp77
74
I recall several years ago a ship damaged the Chesapeake Bay Bridge by plowing through it and taking out several sections.
I have always wondered how they fixed the piling that supports the structure. Since both ends of the damaged portion of the bridge remained, the pilings in the damaged area would have to be driven in the same location as the ones sheared off in the accident.
Can they do that? Are the damaged ends squared up and a new piling driven in the same spot?
Or can they just put forms on the damaged end and pour concrete and extend the existing ones?
How do they affix the rebar, and also, once salt water contacts the damaged portion of the concrete piling, isn't there a problem with the chloride in the fracture area a potential problem in the future?
Or, can they just vary the locations of the replacement pilings to avoid the damaged ones and put the bridge back together with a bit of variation in the span length?It's an amazing bridge, I've never been able to drive over it however.
Can you post a link to an article detailing the incident you're referring to? The only "incident" I could find was at the Chesapeake Bay Bridge-Tunnel (different from the Chesapeake Bay Bridge). The USS Yancey collided with the tunnel bridge during a storm in 1970.
Wikipedia.org said:
In January 1970, Yancey was blown by a storm into the Chesapeake Bay Bridge-Tunnel which closed the structure for several weeks.
http://en.wikipedia.org/wiki/Chesapeake_Bay_Bridge-Tunnel
http://en.wikipedia.org/wiki/USS_Yancey_(AKA-93 )
https://catalyst.library.jhu.edu/catalog/bib_3696520
In general a bridge superstructure is not rigidly connected to it foundations.
So collisions rarely have a great effect at depth.
I do have a humerous story about another bridge strike that I was called out to.
I left 'tunnel' off the OP because I didn't want to be confusing. The Yancey nailed the bridge portion in any event, not the tunnel portion(s). Knocked out quite a chunk.
Can we post pics here somehow?
In any event, in regards to any bridge with a pier knocked out by any ship, how do they put a pier back in the same spot if there is damaged piling and foundation structure where the repairs need to go ??
will try to post pic
Did you not read my last post?
All that you can see in your picture is superstructure.
I have no knowledge of this bridge, but why would they need to replace the elements exactly?
New piles could have been set alongside the old ones.
The old piles could have been extracted and replaced.
Work could have been carried out via a coffer dam or diving bell.
The deck spans could have been varied to suit any new support spacings.
Is there not a local historical archive you can consult?
I am not concerned about the superstructure visible in the picture, I am wondering about the smashed piers/pilings NOT visible in the picture, in the area of the gap in the superstructure, under the water
I was hoping someone who did would reply
I entertained that idea too, did you read my post?
But were they? Oh, that's right, you have no knowledge of this bridge
Fascinating, the pilings might go down 100 feet, what machine can do that, I am very interested, please give details
or not
I entertained that possibility too, did you read my post? But were they?
if I ask here, and manage to get a cogent reply, then we can all find out
Thanks for your help though, interesting considering what I have been through today.
Well it sounds to me like you're going to have to go find out for yourself. Good luck, but be nicer to the librarian if you want useful help.
Question answered as best it can be, nothing useful left to gain, thread locked.
FAQ: Repairing the Chesapeake Bay Bridge
How long will it take to repair the Chesapeake Bay Bridge?
The duration of the repair process for the Chesapeake Bay Bridge depends on the extent of the damage and the specific repair methods used. It can range from a few weeks to several months.
What caused the damage to the Chesapeake Bay Bridge?
The most common causes of damage to the Chesapeake Bay Bridge are natural wear and tear from weather and environmental factors, such as storms and saltwater corrosion, as well as accidents or collisions with ships or other vessels.
Will the repairs make the Chesapeake Bay Bridge stronger?
Yes, the repair process for the Chesapeake Bay Bridge includes reinforcing and strengthening the damaged areas to ensure its structural integrity and safety for future use.
What are the steps involved in repairing the Chesapeake Bay Bridge?
The repair process for the Chesapeake Bay Bridge typically involves a thorough inspection of the damage, planning and designing the repair strategy, obtaining necessary materials and equipment, and then carrying out the repairs. This may include replacing damaged components, reinforcing weakened areas, and conducting quality control checks.
How much will it cost to repair the Chesapeake Bay Bridge?
The cost of repairing the Chesapeake Bay Bridge can vary depending on the extent of the damage and the specific repair methods used. It can range from a few million dollars to tens of millions of dollars. The exact cost will be determined during the planning and design stage of the repair process.
